Poll
How much to get it going, in terms of dollars. Not sweat and aggravation
0-100$
100-150$
150-250$
250-400$
Over 400$
Author Topic: |$220 Stargate. Thrilled!  (Read 3832 times)
pippin65
  • Last login:August 04, 2019, 09:46:13 pm
« on: May 18, 2019, 09:27:35 pm »
Was really happy to find this Stargate.  It suffered terribly in a wet environment prior to my adopting her yesterday.  Drove 7 hours round trip to get her.  I think it’s cool how the cheap top and back mushroomed with moisture and formed like a great stuff- like insulation.  An ablative surface for water intrusion if you take my meaning.
At any rate, for $220 bucks I am an ecstatic owner.  It’s “born on date” is 3/3/82
Any tips and tricks, links to Stargate stuff/ things like that is greatly appreciated.
I was the best player in Bay Ridge back in the day.  I think we should/or I will start a Stargate Senior League!
Question: restore electronics? Or gut it, and put an lcd and pi in there.....
Both.
  • Last login:February 04, 2026, 05:27:25 pm
Re: |$220 Stargate. Thrilled!
« Reply #1 on: May 19, 2019, 01:23:19 am »
I certainly hope you restore it, but if you don’t, consider the 19-n-1 multi board. There is also a much better Jrok board to check out.
pippin65
« Reply #2 on: May 19, 2019, 12:04:49 pm »
Have a rpi on order and an ipac2   Would really appreciate advice from people that have restored a Stargate before.  Parts list?  links to where to begin? basic setup...
Also, as the top and back are totally shot, can I just cut them out(for replacement) without being in fear that the cab. will fall apart?
  • Last login:Yesterday at 11:56:07 am
« Reply #3 on: May 19, 2019, 12:10:16 pm »
Restore, of course
pippin65
« Reply #4 on: May 19, 2019, 12:15:47 pm »
In the interest of restoring it,  I’m thinking I need to gut it after/while taking lots of pictures,  then install an rpi/ipac and game as I get the guts  sorted out, and ultimately re-installed.
« Reply #5 on: May 19, 2019, 12:44:14 pm »
Show us a pic of the top.
I recently updated my defender cabinet with a 19-n-1. Im real happy with it over a computer.
pippin65
« Reply #6 on: May 19, 2019, 01:16:21 pm »
 I’m thinking of just throwing some 1/4 play or paneling on top after hitting it with 3m super 77 adhesive to kinda lock it in....
Zeosstud
  • Last login:February 06, 2026, 10:32:55 am
« Reply #7 on: May 19, 2019, 01:31:47 pm »
if the monitor works.. JROK that bad boy.. Either to a MultiWilliams or a dedicated Stargate, would be just like having the real thing, but with hardware that is not 37 years old..
pippin65
« Reply #8 on: May 19, 2019, 03:34:53 pm »
Can someone show me where to go please? Jrok? Saw a wiring harness for it somewhere....help me ObiWan, you’re my only hope.
nulogix
  • Last login:November 16, 2020, 02:24:59 am
« Reply #9 on: May 26, 2019, 05:43:34 pm »
Restore!  Hopefully the monitor works.  I found one for a steal and  was all stoked then found the monitor doesn't work.  So I'm learning how to repair monitors.
http://www.arcadeshop.com/i/1121/williams-multigame-jamma-pcb.htm  jrok board
http://www.arcadeshop.com/i/892/williams-power-supply-conversion-kit.htm power supply kit
http://www.arcadeshop.com/i/1143/stargate-cabinet-to-jamma-pcb-adapter.htm cabinet to jamma adapter.
Monitor looks like a WG K4600.  Get a cap kit and watch this video
« Last Edit: May 26, 2019, 07:15:46 pm by nulogix »
nulogix
« Reply #10 on: May 26, 2019, 05:45:43 pm »
Shoot if anything you were to part this out on EBAY or KLOV you would probably get more than 220 for boards, control panel, bezel, marquee, coin door.  Great find regardless.
Also, Look at the back side of the monitor on the right.  You will see a little coil of wire.  Don't touch it.  If it's broken then you might be hosed on the monitor.  Lots of ways to fix it, but it's PITA.
« Last Edit: May 26, 2019, 05:47:44 pm by nulogix »
morton
  • Last login:July 23, 2021, 09:36:59 am
« Reply #11 on: May 28, 2019, 07:32:53 am »
Restore if possible.
If it was a junk game with no support/parts available, then do whatever. I feel like the classic games like this will hold some value when restored opposed to cabs that say "Jims Docking Station" and 4567 games on it... unless you find someone named Jim whos always wanted one since 1996.
Its like in Wayne's World when Wayne said " I once spend a whole year wanting a MAME cabinet... turns out I was just really bored".
« Reply #12 on: May 29, 2019, 06:01:04 pm »
Look at it this way, if you part it out you’ll be helping to restore several other stargate cabinets. I wouldn’t feel bad about doing what you want with the cabinet.
« Reply #13 on: May 30, 2019, 03:26:41 pm »
If you're not going to attempt a restore, I'd either resell it to someone who would, or part this out and use the money you make from the parts to buy a better conditioned cabinet, or buy a CNC cut kit.
That wood damage on the top and the bottom is going to be a lot of work to repair.  I'd really only expect someone who is a fan of this game to go the lengths of removing the damaged wood, cutting a "wood patch", bondoing it in, etc...  The top looks crazy as well.  I've seen people separate cabinets to replace damaged panels like this, but those people were taking on a passion project -- grail guys.
