November 23, 2025, 06:05:41 pm
I agree with @adamcian , however youI do disagree on the model of the RGB lights. I ordered one of those rgb lights and I don't think it is very bright without drilling a small hole into the base of the button. I also ordered one of these RGB's and it works a lot brighter.https://paradisearcadeshop.com/en/home/electrical/pcbs-lighting/led-lighting-solutions/button-leds/1835_il-lumination-rgb-5vdc-led-rev-aHow ever with this you will also need this connector, you can use either onehttps://paradisearcadeshop.com/en/home/electrical/wiring-power/harnesses/301_4-wire-100-header-wiring-harnessorhttps://paradisearcadeshop.com/en/home/electrical/pcbs-lighting/led-lighting-solutions/paradise-arcade-kaimana-led-series/1071_paradise-kaimana-3-wire-harness
What I was confused about is where they go on the button. Do they actually live inside the plunger somehow? They don’t have a picture of it on the website that you can see that part and I could tell where/how it attaches. Do you happen to have a good shot?
