Author Topic: Ultimarc Spintrak spinner question  (Read 3595 times)
Scooby
  • Last login:June 01, 2020, 10:15:07 am
« on: April 13, 2019, 01:34:36 am »
Hi guys,
I want to use two Spintrak spinners at the same time. I have difficulties to set one of them to use the „Y“ axis. By default the small USB Interface is set to the „X“ axis. I have a I-PAC2 encoder as well. But it uses the „X“ axis as well and I can‘t find any settings in the WinIPAC tool to change it.
Can someone please give me a hint?
  • Online Online
  • Last login:Today at 04:03:36 pm
Re: Ultimarc Spintrak spinner question
« Reply #1 on: April 13, 2019, 02:14:59 am »
If you aren't using the trackball pins on the I-Pac, pull the Yellow, Green, and White SpinTrak connector pins from the Dupont housing and change the wire order to "Brown-Yellow-Green-White" to use the I-Pac trackball Y-axis pins.
Default SpinTrak Dupont housing wire order: (left)
SpinTrak wire colors:
Brown    +5 Volts
Yellow    X1
Green    X2
White    GND
« Last Edit: April 13, 2019, 02:42:32 am by PL1 »
Scooby
« Reply #2 on: April 13, 2019, 10:05:30 am »
Thx man! That worked like a charm.  :cheers:
Mr. Peabody
  • Last login:November 11, 2025, 07:08:52 pm
« Reply #3 on: April 15, 2019, 04:06:42 pm »
Also, in MAME the axis of each device can be reversed in analog settings.
