Author Topic: mag stick or a mag stick plus color  (Read 3418 times)
daywane
  • Last login:December 26, 2024, 11:02:08 am
  • GRRRR!
« on: March 27, 2019, 09:25:44 am »
i have 2 mag sticks 1 mag stick plus
has any one changed the color?
I have some old hap leafs 4 way ball top also wrong color for what I want.
how well would  5 coats of spray paint and 5 coats of clear hold up?
Any other ideas would be grateful
daywane
  • GRRRR!
Re: mag stick or a mag stick plus color
« Reply #1 on: March 27, 2019, 11:07:38 am »
maybe automotive paint? I have sprayer and air compressor?
Titchgamer
« Reply #2 on: March 28, 2019, 06:00:46 am »
What colour do you want to go from to?
daywane
  • GRRRR!
« Reply #3 on: March 28, 2019, 06:40:11 am »
That red bat type joystick's
I want 1 pink
Titchgamer
« Reply #4 on: March 28, 2019, 07:39:00 am »
You could try bleaching one?
If it was lighter to darker easy but the other way round not so much lol
  • Last login:July 27, 2025, 11:06:50 am
« Reply #5 on: March 28, 2019, 06:07:55 pm »
That pint will eventually wear off. Maybe some kind of dye?
Mr. Peabody
  • Last login:March 05, 2025, 05:44:10 pm
« Reply #6 on: April 01, 2019, 03:18:15 pm »
Epoxy paint.
MartyKong
  • Last login:July 21, 2025, 05:31:48 pm
« Reply #7 on: April 01, 2019, 05:04:52 pm »
 I painted a Happ reunion joystick from red to yellow. It has held up remarkable well. I suggest you start off sanding the ball down really well. Tape off areas as needed and spray multiple coats sanding as you go. Remember to allow it to cure well before using it.
MartyKong
« Reply #8 on: April 01, 2019, 05:09:20 pm »
Oh, One more thing. I think my first several coats were with a Krylon primer designed for plastic. After that I applied paint. Hope this helps :)
daywane
  • GRRRR!
« Reply #9 on: April 01, 2019, 07:57:05 pm »
