Author Topic: Mortal Kombat bootleg pcb speaker question  (Read 4030 times)
amiga500
  • Last login:December 29, 2024, 10:09:10 pm
« on: March 19, 2019, 09:26:29 pm »
Not sure if this is the right section to ask this, but I would like to know what kind of speaker (ohms, Watts) should I add to this board without damaging it or the speaker itself.
The amp on the board is a uPC1241H, I've found some info that says it's a 5 to 11w amp and that it can manage a 2 Ohm to 4 Ohm load ??
I'm not sure I understand what the datasheet says, so, what is the most suitable speaker I could connect to this board?
Could I connect 2 speakers? How?
here is some info about the amp: http://malzev.tripod.com/comp/upc1242.htm
Datasheet: https://cdn.datasheetspdf.com/pdf-down/U/P/C/UPC1241H_NECElectronics.pdf
« Last Edit: March 19, 2019, 10:12:46 pm by amiga500 »
RV88
  • Last login:April 25, 2019, 11:48:44 am
Re: Mortal Kombat bootleg pcb speaker question
« Reply #1 on: April 25, 2019, 11:47:18 am »
Hello,
On your schematic, I can See speaker output: 4ohms. It's the minimal value, you can ad.
You can put two speakers but the minimal ohms will be 8hms, because you will connect them in parallel, which make them as a single speaker with 4 ohms load.
and uPC1241H is a mono output
