Author Topic: Joystick Restrictor Material  (Read 3436 times)
D_Harris
  • Last login:September 25, 2024, 10:06:48 pm
« on: February 11, 2019, 05:11:48 pm »
I'm looking ofr advice from those here who have had to replace a joystick restrictor.
What is your experience with the plastic vs. the metal ones as far as wear?
I assume the metal restrictors would last longer, but there would be more wear on the joystick itself where contact is made. (Though I assume that either restrictor can be thickened to improve overall durability).
I'm curious because I'm trying to settle on the most durable material option so I can reproduce some.
Thanks.
Darren Harris
Staten Island, New York.
My collection:Asteroids, Joust, Millipede, Ms. Pac-man, Pole Position, Robotron 2084, Star Trek, Star Wars, and 100+ PCBs. Trading/Selling:Arkanoid: R.O.D. Cocktail, Tornado spinner, Hewlett Packard 16500A Logic Analysis System with Accessories. Wanted:Mach 3 joystick. Millipede Trackball. 100° or WG4600 monitor Tube.
Mr. Peabody
  • Last login:March 05, 2025, 05:44:10 pm
Re: Joystick Restrictor Material
« Reply #1 on: February 20, 2019, 06:57:23 pm »
Stick makes and in some cases models have specific types. Except for the Kowal repro'd stuff, I have seen plastic. It seems to last many moons if one isn't destructive.
D_Harris
« Reply #2 on: February 24, 2019, 01:34:10 pm »
I plan to use my milling machine to make some. But I'm wondering if anyone has ever had to replace a joystick because of damage from use in a metal restrictor like that in a Nintendo joystick assembly.
Darren Harris
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
« Reply #3 on: February 24, 2019, 11:42:00 pm »
BLASPHEMY !
Nintendo joysticks are INDESTRUCTIBLE !
killallhumans
  • Last login:May 21, 2021, 06:57:37 pm
  • What does this red button do?
« Reply #4 on: February 25, 2019, 01:01:19 pm »
Installing a gate will prevent players from smashing stock restrictor.
Auto•It 3 fixes everything.
Game loading, lights, sounds,
control mapping, screen rotation...
Compile scripts to EXEs and drop them
into your arcade Frontend.
D_Harris
« Reply #5 on: February 27, 2019, 03:18:41 pm »
?!? What is a "Gate"?
Darren Harris
killallhumans
« Reply #6 on: February 27, 2019, 10:58:23 pm »
Used mainly for industrial control sticks or shifters, it is an impact resistant 1/4 inch thick sheet of urethane, cut to size,
drilled, and routed with holes or slots to guide control shaft. It is mounted over stick base, as seen in picture.
Whereas your restrictor is not meant to protect anything, but only to prevent wrong switch activations, and is probably
made of acrylic or ABS plastic. If you know the concept of levers and fulcrums, your restrictor is receiving more force, than
that which is applied to the top of joystick ball. The shaft is made of hardened (heat treated) steel. Guess who the winner
will be. Going industrial may seem a wee bit like overkill, but you won't be replacing joystick parts so often.
I hope this was a little more helpful than just posting a picture (I put a lot of thought and work into that picture).
Anyway, good luck with your arcade.
- David
ps
Don't use your top plexiglass for that. It will end up looking like a CD jewel case that was stepped on.
OR:
just add one of these to your cp from an old car alarm. runs off 5 volts. Connect trigger wire to computer power button.
Next time someone gets too rough with your arcade, this baby will shut everything off.   :hissy:   :laugh2:
« Last Edit: February 27, 2019, 11:38:12 pm by killallhumans »
D_Harris
« Reply #7 on: February 27, 2019, 11:20:12 pm »
So  basically, this "gate" is a bumper/cushion located above the joystick axis? And would that just be another part to wear out?
BTW. The restrictors I'm making will be 1/4" thick and flared to match the joystick angle upon contact.
Darren Harris
killallhumans
« Reply #8 on: February 27, 2019, 11:44:24 pm »
No, because hard urethane is much more impact resistant, yet gives slightly.
Racing motor mounts are made of the same stuff.
Whatever you choose, don't do metal on metal with your actuator and restrictor.
Your stick won't last very long, and you'd never want metal dust or shavings floating
around in your cabinet.
« Last Edit: February 27, 2019, 11:58:53 pm by killallhumans »
ark_ader
  • I glow in the dark.
« Reply #9 on: February 28, 2019, 06:03:41 am »
I'm curious is PLA would be rigid enough for a restrictor, if we 3D print some, instead of buying it.  It would make for some interesting configurations.
killallhumans
« Reply #10 on: February 28, 2019, 06:18:58 am »
Polylactic acid - Wikipedia
https://en.wikipedia.org/wiki/Polylactic_acid
Poly(lactic acid) or polylactic acid or polylactide (PLA) is a biodegradable and bioactive thermoplastic aliphatic polyester derived from renewable resources, such as corn starch (in the United States and Canada), cassava roots, chips or starch (mostly in Asia), or sugarcane (in the rest of the world).
Biodegradable...
What do you think?
New shopping bags are made of it. They fall apart, (re)turning to flakes of starch, in only a few months.
It may keep worms and tree huggers happy. I however, wouldn't be singing and dancing.
Another fun fact, it attracts roaches. They can eat it. Mixed in a suspension medium, it's used in roach bait gels.
« Last Edit: February 28, 2019, 07:08:27 am by killallhumans »
D_Harris
« Reply #11 on: March 06, 2019, 03:58:41 pm »
I'm assuming if placed right the "Gate" will not interfere with the restrictor doing it's job. But why not just make the restrictor out of hard urethane and forget the "Gate"?
As for mine, it's down between steel and Delrin.
Darren Harris
Mr. Peabody
« Reply #12 on: March 07, 2019, 03:00:38 pm »
Biodegradable...
What do you think?
Nearly anything food-sourced will be problematic - except hemp, and pepper/curry-related things.
Even in apartments, roaches exist mainly when tenants have un-rinsed dishes, dishes with food in other rooms......
« Last Edit: March 10, 2019, 04:10:06 pm by Mr. Peabody »
