Author Topic: Star Wars Trilogy USB Joystick  (Read 14966 times)
kooky
  • Last login:June 22, 2025, 01:21:45 pm
  • My Motto is "More Good Times"
« on: February 11, 2019, 03:11:28 pm »
I am putting together a combo shooter (AimTrack) and flight stick cabinet.  I'd like to play Star Wars Trilogy but I can add others if they are compatible with the joystick I select.
Can I get away with an 8-way trigger stick (https://www.amazon.com/Flight-Joystick-Trigger-Button-Arcade/dp/B0786NFSLM) or do I need to use an analog stick for this game?  Does anyone have any recommendations for a USB flight stick that only has two buttons?  I've only seen flight simulator joysticks with a ton of buttons or the Ultrastik 360 with flight trigger attachment.
Zebra
  • Last login:August 19, 2021, 01:12:24 pm
Re: Star Wars Trilogy USB Joystick
« Reply #1 on: February 11, 2019, 04:18:43 pm »
Maybe you can find the real arcade controls for that game. Or a flight stick from another arcade.
You can connect analog arcade joysticks to a PC easily with an Apac or equivalent. I use one to connect my Gunblade and Operation Thunderbolt guns.
I find that real arcade controls, even if they are used, just feel better than any consumer peripherals.
nitrogen_widget
  • Last login:September 12, 2025, 07:07:08 pm
« Reply #2 on: February 11, 2019, 04:20:43 pm »
I was playing around with this on my PC the other night and wondering the same.
would something like this work with a zero delay encoder or would it make your hand cramp up?
$25
https://www.ebay.com/itm/Arcade-flight-yoke-stick-Joystick-8-way-joystick-w-two-fire-buttons-firm-grip/232354256149?epid=1930922596&hash=item3619649515:g:ukkAAOSwsn9b~cbg:sc:USPSFirstClass!14094!US!-1:rk:1:pf:0
  • Last login:Today at 03:22:22 pm
« Reply #3 on: February 11, 2019, 04:23:56 pm »
Star Wars Trilogy is an analog stick game.
There's a list of analog stick games here.  (backup of the wiki page)
If you want an analog USB flightstick, here's one great choice.   :cheers:
https://www.amazon.com/gp/product/B00006B84V/
Another stick that several other forum members have recommended is the Thrustmaster T16000M FCS.
« Reply #4 on: February 11, 2019, 05:16:30 pm »
Yes, it will work just like any 8-way (microswitch) joystick and two push buttons.
You linked to the short shaft version with only 3/8" clearance between the mount plate and the bottom of the stick.
- On a wood panel, you'll need to top mount it.
- With the dust washer installed, there is only room for about 1/8"/3mm plexi or a 3d printed cover for the mounting plate. (LMK if you want the OpenSCAD code for a cover)
Some vendors like Ultimarc sell a longer shaft version.
Depends on the player, the game, CP layout, etc.   :dunno
Braddiest90
  • Last login:February 28, 2019, 07:09:18 am
    • Flirtlu
« Reply #5 on: February 12, 2019, 01:24:01 am »
Does anyone remember how many buttons the Tie Fighters actually had in the movies? And were they red buttons?
kooky
« Reply #6 on: February 12, 2019, 10:55:50 am »
Tie Fighter or X-Wing? X-Wing was what Luke flies in the first movie.  The X-Wing had a flight stick similar to the one PL1 listed (Thanks by the way I will probably buy this):
  • Last login:Yesterday at 07:12:04 pm
« Reply #7 on: February 12, 2019, 02:12:51 pm »
I just picked up a pacific av8r ps3 flight stick for a similar purpose.  Strangely, the analog thumbstick can't be used in windows, but other than that it's full featured, has an ambidextrous arcade style grip, and retails for around 20 bucks at this point.  Quality stick for the price... highly recommended.
