Author Topic: Hantarex mtc-9000, red missing  (Read 2271 times)
paolinux78
  • Last login:October 04, 2021, 06:00:18 pm
« on: February 08, 2019, 06:30:07 am »
Hello everyone, I own the monitor MTC-9000 and the image is this, it seems that there is a red color, I proceeded to replace all the electrolytic capacitors and the 3 transistors on the neckboard, but without any result, what can I do?
« Last Edit: February 08, 2019, 06:32:06 am by paolinux78 »
paolinux78
Re: Hantarex mtc-9000, red missing
« Reply #1 on: February 08, 2019, 06:31:20 am »
the correct colors should be like this:
grantspain
« Reply #2 on: February 08, 2019, 11:01:21 am »
does it have a pot or 3 switches for contrast?
if you ground the red gun do you see red on screen, if you swap red and blue on the input connector does the signal appear for both?
grantspain
« Reply #3 on: February 08, 2019, 11:02:46 am »
actually scrap that, you either have a bad tube or very poorly adjusted colours, contrast and brightness
itrimcevski
  • Last login:July 15, 2019, 05:54:53 pm
« Reply #4 on: July 15, 2019, 05:54:53 pm »
I have the exact same problem. Its not the tube and transistors and pots on the neck are just fine. Any help is welcomed.
