Author Topic: Prevent light from bleeding through bottom and sides of marquee?  (Read 2101 times)
obizues
  • Last login:June 11, 2023, 06:17:35 pm
  • Before you start your next project, don’t.
Is there a “best” way to stop light from bleeding through the sides of a marquee?
My goal is to not have a dark spot from putting a big piece of wood on the other side that creates a shadow.
Re: Prevent light from bleeding through bottom and sides of marquee?
« Reply #1 on: January 26, 2019, 05:49:35 pm »
You should have an L shaped retainer on the front that's the same height or taller than the block of wood on the back.
I don't know a good solution for the sides.  On my own cab, I used sticky butyl rubber peeled off sound deadening panels.
Rolled it into a thin strip and worked it into the sides with the edge of a credit card.
Nobody notices it, but I've never been completely happy with it.
MartyKong
  • Last login:November 24, 2025, 01:22:36 pm
« Reply #2 on: January 26, 2019, 08:59:25 pm »
Had the same question when building my cab. I cut several pieces of plexi choosing the one that fit the tightest before applying my marquee. There's still a tiny bit of light but overall I'm satisfied. If you've already cut yours, a narrow
piece of weather stripping may help.
  • Last login:Yesterday at 04:31:53 pm
« Reply #3 on: January 26, 2019, 09:04:53 pm »
Weather stripping.  Electrical tape.
meany
  • Last login:May 01, 2019, 02:12:23 pm
  • Atomic batteries to power, turbines to speed....
« Reply #4 on: February 06, 2019, 01:57:34 pm »
Use a black sharpie on the 1/4" edge of the marquee.
