Author Topic: [FS-CT] $150 obo. RGB Modded Trinitron KV-FV300 for GroovyMame / Consoles  (Read 1958 times)
nipsmg
  • Last login:Yesterday at 03:53:40 pm
  • ROONEY!! ERRGH!!
    • Arcadia
RGB Modded Sony Trinitron KV-FV300 with remote - $150 obo. Works amazing.  Local pickup only (in central CT)
Sound on this set is incredible,has a built in subwoofer and gives amazing sound.
Wired to VGA port on back with a switch to turn on/off mod (in case you want to use stock inputs).
Pins 1-3 R,G,B
Pin 5 - Gnd
Pins 13,14 Hsync,  Vsync
The picture is much more vivid and bright in person.
Modded using OSD mux method, OSD can still be used while using RGB mod (for volume, picture adjustment, etc.)
