Author Topic: Joystick removable shaft.  (Read 3880 times)
trekdrop
  • Last login:January 22, 2019, 08:55:51 am
« on: January 22, 2019, 04:44:40 am »
Hi, for my project I am looking for a removable shaft joystick. I only can find stuff you can buy in USA only I live in Holland and that is really expensive. Can anyone tell me how to make this from a normal one or can I buy something like this on AliExpress?
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
Re: Joystick removable shaft.
« Reply #1 on: January 22, 2019, 06:12:46 am »
Not sure what you mean. Most joysticks allow the shaft to be removed by popping off the clip on the bottom.
« Last Edit: January 22, 2019, 07:16:19 am by big10p »
Titchgamer
« Reply #2 on: January 22, 2019, 07:11:23 am »
Not sure what you mean. Most joysticks allow the shaft to be removed by popping of the clip on the bottom.
What he said ^
If you are looking for a easy remove solution that can be removed from the top I dont know of any.
  • Last login:Today at 04:49:10 am
« Reply #3 on: January 22, 2019, 08:30:19 am »
Pretty sure he's looking for something like the top-removable replacement shaft The Link by Phreakmods.
Focus Attack carries them in various colors for JLF, LS-32, and LS-56 sticks.
Paradise Arcade Shop also carries them here.
Not sure if there are any European vendors that stock them.   :dunno
trekdrop
« Reply #4 on: January 22, 2019, 08:44:07 am »
Yeah this one above post, is it possible to make this?
« Reply #5 on: January 22, 2019, 10:13:07 am »
Making one from scratch is almost certainly going to be more expensive than shipping and it probably won't work as smoothly.
- I assume if you had access to a metal lathe that could also cut threads you wouldn't be asking if making a top-removable shaft was possible.
1. You may want to ask clayton@phreakmods.com if there are any European vendors that carry The Link.
2. If there aren't any European vendors, get shipping quotes from Focus Attack and Paradise Arcade Shop.
- A banner on the Focus Attack page mentions "save 25% on global shipping".   ;D
barrymossel
  • Last login:October 29, 2021, 11:25:52 am
  • Spectrum
« Reply #6 on: January 23, 2019, 11:09:22 am »
You could ask Arno from Arcadewinkel.nl if he can order those from one of his international vendors...
pixel
  • Last login:December 24, 2019, 05:33:55 pm
« Reply #7 on: January 25, 2019, 02:39:27 pm »
 Modding an existing joystick for quick-removal would not be that difficult.
 You could use one of the many existing quick-connects that are usually sold as Drill or screwdriver attachment kits.
(Air-hose connects could be used too... but... those tend to be thicker in diameter)
 You then would just
 - cut the original joystick shaft
 - grind a notch on the bottom end of the shaft with a dremel, or maybe a round metal file.
 - Once the fit works properly with the adapter,  then cut the adapter shaft to desired length
 - Round (grind) the end portion of the typically hexagonal shaft of the adapter
 - Cut off the ball of the original stick, and drill a hole to match the adapter shaft end.
     (if no ball exists, buy a wooden ball, or plastic ball,  that best suits the size desired)
 - Use Epoxy, or Epoxy paste, to permanently glue the shaft into the ball (or bat top).
   * Note: Make sure epoxy is mixed extremely well... especially true with epoxy putty.
 - Wait 24 hrs for full cure before use.
Mr. Peabody
  • Last login:November 11, 2025, 07:08:52 pm
« Reply #8 on: January 27, 2019, 02:00:43 pm »
How about a heavy-duty key chain splitter?
