Author Topic: Having some trouble getting d3d9ex to work and super resolution trouble  (Read 8341 times)
lilSkeeter
  • Last login:January 15, 2019, 05:54:02 pm
Hello all. I have a PC with win10 running grooveymame 194 on a sony trinitron with a vga to component transcoder. I have been running it for a while but it wasnt really setup right or something, super resolutions didn't seem to be working quite right. I couldn't launch many game also. So I started looking in to it and I found I may not have set up the super resolutions right or something. There is a lot of confusing and scattered  threads on the matter. So I reckoned to make a thread and here I am, I need help my dudes.
I found http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=290 and have been trying to go through it to get everything working and alonng the way have ran in to some problems. When I change video  auto to video  d3d9ex in mame.ini and launch mame64 I am only getting a black screen. . I launch mame with command line with a game and get this in the command window: invalid video value d3d9ex reverting to gdi while the screen is black and the sound is going all crazy fast forward highpitched.  If I use video auto, mame will launch. There are other issues but I will focus on this one first if anyone can lend me a hand or three!
lilSkeeter
Re: Having some trouble getting d3d9ex to work and super resolution trouble
« Reply #1 on: January 13, 2019, 10:10:04 pm »
also i am not seeing where I can upload the txt log.
lilSkeeter
« Reply #2 on: January 13, 2019, 10:12:30 pm »
OK I see how to upload attachments now whoops. here is where I tried to run sf2 with d3d9ex enabled. Apparently it was running in the background while the screen was black.
lilSkeeter
« Reply #3 on: January 13, 2019, 11:07:07 pm »
well i think I may have actually downloaded the version without d3d9ex? I just now was looking in the google drive download area for 194 groovymame and saw there is a version called grooveymame64_194_017g and another called grooveymame64_017g_d3d9ex. I think I had installed the one without the d3d9ex. I am trying to download the other one and mess with it now.
Arroyo
  • Budgets are boring
« Reply #4 on: January 14, 2019, 08:38:31 am »
Download the one that has d3d9ex.  You just need to put d3d under the video section and you are good to go.  Using video = d3d9ex has been depreciated, instead it’s now d3d.  You are still getting d3d9ex it’s just the call for it in the mame.ini has changed.
lilSkeeter
« Reply #5 on: January 14, 2019, 09:37:18 am »
Yea thanks arroyo, I downloaded the d3d9ex version and put video d3d9ex and it still didn't work. Is there an updated guide that has the correct "up to date" information out there?
Calamity
  • Moderator
  • Last login:Yesterday at 05:28:27 pm
  • Quote me with care
« Reply #6 on: January 14, 2019, 09:48:11 am »
That guide is outdated.
New versions don't use -video d3d9x anymore. Just leave the default -video auto and GM will automatically enable D3D9ex, as long as you downloaded the correct _d3d9ex build.
Steps to create a log:
Arroyo
« Reply #7 on: January 14, 2019, 09:50:59 am »
Probably a silly question, but do you have direct x installed on your computer?
lilSkeeter
« Reply #8 on: January 14, 2019, 10:36:07 am »
Hmm I don't know, it's just a standard fresh windows 10 install so if it's something extra I don't think so.
lilSkeeter
« Reply #9 on: January 14, 2019, 10:38:54 am »
dxdiag shows directx 12 is installed
lilSkeeter
« Reply #10 on: January 14, 2019, 10:56:32 am »
also thanks for everything calamity! This is actually a DIY arcade cabinet I built for my daughter for her birthday and we have had a lot of good hours playing all kinds of mame roms on the crt thanks to your software! Now I just wanna fine tune it and make the screens fit right among a few other issues.
Arroyo
« Reply #11 on: January 14, 2019, 12:21:37 pm »
Sounds like you do.  Sounds like you should go with video = auto as Calamity suggested, just seemed weird to me cause d3d worked for me.  As long as you see good scanlines and “pixels” you should be good.
krick
  • Gotta have blue hair.
« Reply #12 on: January 14, 2019, 04:06:45 pm »
On Windows 10, you need to install DirectX 9.  Here's the full offline installer...
https://www.microsoft.com/en-us/download/details.aspx?id=8109
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Arroyo
« Reply #13 on: January 14, 2019, 04:20:43 pm »
I thought I read online (and seemed to experience when trying), that you couldn’t go down in version with Direct X?  As it appears he as Direct X 12, is there a way to rollback?
Calamity
  • Moderator
« Reply #14 on: January 14, 2019, 04:51:05 pm »
No need to rollback. You'll have DX12 (Windows 10's native) AND DX9 (Windows 10 only ships with basic compatibility DX9 features, you need a specific download to get all of it running).
Anyway OP's issue not caused by lacking DX but by the use of deprecated GM video options as explained above.
Arroyo
« Reply #15 on: January 14, 2019, 04:55:09 pm »
Ah I see, it’s OS specific, I am running Windows 7 and had downloaded I believe it is Direct X 11, and in reading tutorials thought maybe I needed version 9 specifically.  Thanks for clarifying.
lilSkeeter
« Reply #16 on: January 14, 2019, 05:56:56 pm »
I downloaded that directx 9 file. When I run it it, it just extracts a whole bunch of files into a folder, is that right? It asked me where to extract and I made a random folder for it. Is that it? It still shows direct x 12 on dxdiag.
krick
« Reply #17 on: January 15, 2019, 08:07:59 am »
Sorry, I guess more instructions would have been helpful. :)
It should have downloaded this file...
directx_Jun2010_redist.exe
When you run the file, it will ask you where to extract it.  Extract it somewhere with a simple path like C:\dx9redist
Once it extracts, go into that folder and run this file...
DXSETUP.exe
Hantarex Polo 15KHz
lilSkeeter
« Reply #18 on: January 15, 2019, 12:59:54 pm »
thx bud
