Author Topic: How to edit mame.ini file  (Read 5798 times)
pumpkinpie
  • Last login:September 03, 2023, 02:58:17 pm
« on: January 11, 2019, 10:07:59 pm »
Hi all - i read this post - http://forum.arcadecontrols.com/index.php?topic=147163.0 and would like to do what is instructed to the mame.ini file but have absolutely no idea how to do this - have not used command line very much, so would someone be able to let me know how to go about doing this ?
Much appreciated !
Arroyo
  • Last login:September 12, 2025, 06:46:27 pm
  • Budgets are boring
Re: How to edit mame.ini file
« Reply #1 on: January 12, 2019, 12:14:35 am »
Much appreciated !
Go to the folder that your Mame program lives.  There should be a file mame.ini.  Simply double clicking it should bring up the file in either Notepad or another text editing program.  If not then use your preferred text editor to open it.  Once opened scroll down to any of the values you want to change such as multi mouse and put a 1 where you want the function on, a 0 where you want something off.  No command line needed.
You can also find these options when you launch Mame under I believe it’s advanced options.
pumpkinpie
« Reply #2 on: January 12, 2019, 10:19:11 am »
well thank you - that was easy !
pumpkinpie
« Reply #3 on: January 12, 2019, 06:18:44 pm »
[quote author=Arroyo link=topic=159283.msg1675106#msg1675106 date=1547270075
[/quote]
hey any idea on how to do this on a retropie setup ?
Arroyo
« Reply #4 on: January 12, 2019, 06:27:09 pm »
Sorry never played with a Pi.  I’m sure someone else on here could help.
keilmillerjr
  • Web Developer.
« Reply #5 on: January 13, 2019, 04:45:43 am »
$ nano mame.ini
