Author Topic: GroovyArcade (Linux) running slow on vert games  (Read 2695 times)
jimmyj1979
  • Last login:May 02, 2022, 07:26:01 am
« on: January 04, 2019, 03:33:28 am »
Hey guys
I have a functional GroovyArcade setup now and most things are working great. I have a 15khz Nanao monitor working with my J-Pac and my ATI 45xx card.
The main issue is vert games are running at the wrong speed. either 50% or 75% of their proper speed. Any ideas? I did some googling but before i started tinkering i thought id ask the experts :)
Jim
Doozer
  • Last login:June 12, 2023, 09:19:49 am
  • Z80 ERROR
Re: GroovyArcade (Linux) running slow on vert games
« Reply #1 on: January 04, 2019, 04:29:58 am »
Hi jimmyj1979,
It looks like your kernel do not have the interlaced resolution fix. Are you using the GA kernel or have you built your own?
jimmyj1979
« Reply #2 on: January 04, 2019, 07:57:24 am »
Hi mate
I am running the standard GA kernel. Any ideas or thoughts on how to remedy this?
Thanks in advance.
Jimmy
Doozer
  • Z80 ERROR
« Reply #3 on: January 04, 2019, 08:25:56 am »
Hi mate
Thanks in advance.
Jimmy
If you know how to build  your own kernel, it will be easy to fix the issue. I have recently posted the patch to apply to the kernel source to fix the interlaced vblank interrupt routine. Unfortunately, I am away from computer and do not have easy mean to search the forum.
jimmyj1979
« Reply #4 on: January 04, 2019, 06:07:08 pm »
Thanks mate, sounds like you know what youre talking about! When you get a moment if you could find that thread you mentioned it would be highly appreciated :)
Peace!
jimmyj1979
« Reply #5 on: January 08, 2019, 08:55:56 pm »
I ended up with an adhoc fix
inside the /home/arcade/.mame folder i created an ini file for each vert shooter i wanted to play. For example if they rom was called jimmyj1979.zip i created jimmyj1979.ini and in that ini just put 'Resolution 240x320'. The games dont quite look right being a bit squashed but they run full speed with no tearing. Definitely playable until I get a cab with a vert monitor :)
Doozer
  • Z80 ERROR
« Reply #6 on: January 09, 2019, 05:15:54 am »
Peace!
Hi,
My fault, I haven't seen your post until today. Here is the fix for interlaced resolutions. It applies up to kernel 4.20.
Cheers!
Code: [Select]
--- linux-4.12_64/drivers/gpu/drm/drm_irq.c     2017-07-02 23:07:02.000000000 +0000
+++ linux-test-4.12/drivers/gpu/drm/drm_irq.c   2017-08-15 08:33:14.318147395 +0000
@@ -243,8 +243,9 @@
                      pipe, vblank->count, diff, cur_vblank, vblank->last);
        if (diff == 0) {
-               WARN_ON_ONCE(cur_vblank != vblank->last);
-               return;
+// AWK         WARN_ON_ONCE(cur_vblank != vblank->last);
+// AWK         return;
+               diff = 1;
jimmyj1979
« Reply #7 on: January 09, 2019, 05:07:58 pm »
great! Thank you mate!
