Author Topic: unable to use resolution other than super resolution  (Read 2134 times)
punkysuen
  • Last login:February 12, 2022, 12:25:37 am
« on: January 03, 2019, 12:16:05 pm »
I have an arcade cabinet Sega New Net City with a try-sync monitor, and I hook it with PC to run emulators.
I am using Windows 7, and my video card is AMD R9 290 4GB, without VGA and DVI-I ports, so I use HDMI-to-VGA adapter.
I have installed crt_emudriver and followed the guide to install modes by super resolutions.
Everything goes fine when I play GroovyMAME, super resolutions are great.
By GroovyMAME, every 15KHz and 25KHz games show properly.
However, when I play Nebula's Model 2 emulator, the image is abnormal if I choose super resolution 2560x384.
I cannot find "Image Stretch" function on this emulator.
Therefore, I tried to add 496x384 by editing the txt of super resolution.
The result is "No Signal".
After trying different settings, I found that native 640x480p works normally, all other custom resolutions (like 320x240, 496x384) fail.
What I can use are super resolutions only.
Anything I can do to use custom resolutions?
Thank you very much!
Calamity
  • Moderator
  • Last login:Today at 05:54:44 am
  • Quote me with care
Re: unable to use resolution other than super resolution
« Reply #1 on: January 07, 2019, 05:21:12 pm »
Are you using CRT Emudriver beta 14?
Steps to create a log:
