Author Topic: Can't compile dmame 79?  (Read 2667 times)
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« on: February 09, 2004, 01:58:26 pm »
I can't seem to get Dos mame to compile, keep getting the error    Invalid Switch  /dmame.......
Can anyone help?
Also, I followed the dos compiling enviroment set up that's outlined on mame.net, but no luck?
Thanks,
Steve
Buddabing
Re:Can't compile dmame 79?
« Reply #1 on: February 09, 2004, 04:03:42 pm »
Can anyone help?
Thanks,
Steve
What command line are you using for make? You should use "make MAMEOS=msdos", or change the makefile.
Also, what OS is the compiling computer running? DOS MAME won't compile on a computer that doesn't have long file name support. It'll run, but it won't compile.
Good luck!
Buddabing
Please read the wiki!
creatine28
« Reply #2 on: February 09, 2004, 04:11:38 pm »
Good luck!
Buddabing
I'm using the   make MAMEOS=msdos  command.  Also, I'm using windows 98 and running the compiler via a DOS prompt.
How can I make my computer support long file names?
I think that might be my issue,  because when I look at a directory through a DOS prompt, my files names are shortened from something like   mame79++.exe    to    mame7~1.exe.
Just read this on google!
 djgpp.env disables long filnename support.
At the time the developers weren't sure whether or not it was
stable enough.  Now that we know that it is, set LFN=y in your
autoexec.bat and you'll get the long filenames back.
So, should I just add ..
"  Set LFN=Y  "    in my autoexec before I envoke the DJGPP.env?
« Last Edit: February 09, 2004, 04:36:27 pm by creatine28 »
Buddabing
« Reply #3 on: February 09, 2004, 07:18:07 pm »
Good luck!
Buddabing
You can do the SET LFN=Y from anywhere in your autoexec. I tried it and it works for compiling from a DOS prompt within Windows. I tried under Windows 98FE.
So you should be good to go unless you want to compile on native DOS.
creatine28
« Reply #4 on: February 09, 2004, 07:30:38 pm »
Cool, thanks!   I'll give it a try!
creatine28
« Reply #5 on: February 10, 2004, 01:57:16 pm »
Dang!  It didn't work!     I guess as a last resort, I'm going to try to load the Compiler on my older system that has win 95.
Oh well!
Thanks for the help anyways!
Steve
« Last Edit: February 10, 2004, 04:10:30 pm by creatine28 »
creatine28
« Reply #6 on: February 16, 2004, 04:42:47 pm »
Finally seemed to get it to work!   My problem was I had a copy of make.exe in the same directory as my mame source,  so it was like make.exe was been called twice.  Once when I run my compiler.bat (Which envokes DJGPP director/bin) and another just from make.exe being in my Source directory.  I erased the extra make file and it worked perfectly.
Steve
