Author Topic: Emudriver SAPPHIRE HD 7870  (Read 5127 times)
Juanjillu
  • Last login:February 26, 2019, 01:55:36 pm
« on: December 14, 2018, 04:13:27 pm »
Greetings from Seville, Spain!
I have a sapphire HD 7870 and I have installed emudriver and groovymame. Except the bottom in vertical games like donkey kong the rest goes PERFECT. I have a problem with non-mame emulators. Model2, supermodel, demul (with naomi goes perfect, with dreamcast fails). I can not use them in full screen. In the case of model 2 it closes, and the rest shows frequencies out of range. I have tried the windows option (I have windows 10) to hide the modes not supported by the monitor, but it is still the same. The drivers I used are (Crimson 16.2.1 for GCN cards) with an HD 7350 and the drivers (Catalyst 12.6 ) everything is correct so I understand that my monitor (it's a TV) is not the problem. What I can do? I am already desperate. Best regards
Zebidee
  • Trade Count: (+9)
  • Last login:January 07, 2026, 10:22:02 am
Re: Emudriver SAPPHIRE HD 7870
« Reply #1 on: December 14, 2018, 10:28:44 pm »
Are you sure that you have appropriate video modes installed for those emulators/games?
GM simply chooses the best mode from what's available, so will usually just "work", but other emulators typically use specific modes and if you don't have them, won't work right (Disclaimer: I say that generically, I don't actually use the emulators you mentioned other than GM).
Check your help, ini and log files, if available, to see what video modes your emulators are looking for.
buttersoft
  • Last login:Today at 01:01:32 am
  • Is running at 15kHz
« Reply #2 on: December 14, 2018, 10:29:24 pm »
Have you already tried to stop and disable the windows service called AMD External Events Utility? Type services into the start menu to get to it.
Juanjillu
« Reply #3 on: December 15, 2018, 02:30:54 am »
Thanks for answering. I have the AMD service stopped and disabled. If I focus on model 2, the resolution of the recently downloaded emulator is 640 x 480 (it works, but if I use full screen, it locks and closes). If I configure it with its native resolution, 496 x 384 I believe it in vmmaker but the one that installs me is:
496x486_60 15.81KHz 60.00Hz "10.24 496 520 568 648 486 488 494 527 interlace -hsync -vsync
I am using the monitor presets: arcade_15 "," Arcade 15.7 kHz - standard resolution "," 4: 3 "
What can happen? it is only with full screen
I run out of ideas from so much to try :(
Calamity
  • Moderator
  • Last login:Yesterday at 05:28:27 pm
  • Quote me with care
« Reply #4 on: December 15, 2018, 07:17:05 am »
Model 2 crashes if there's no sound output, e.g. if you don't have speakers or headphones connected.
Steps to create a log:
Juanjillu
« Reply #5 on: December 15, 2018, 08:15:34 am »
In my case if I have the sound well connected. Even if I launch it without a full screen it works fine. Before I tried using another monitor preset (I think it was high definition) and if it starts but it looks double (the same image on the left and right) and with a lot of blinking. With my previous graphic it works fine but with the 7870 hd not :(
Juanjillu
« Reply #6 on: December 16, 2018, 09:13:42 am »
Here you can see what happens to me:
Juanjillu
« Reply #7 on: December 22, 2018, 01:02:19 am »
hello good. Has nothing happened to anyone? :( I do not know what else to play
Juanjillu
« Reply #8 on: December 30, 2018, 04:18:07 am »
Greetings. I just tried the same graphics card, on the same TV screen, with the same emudriver but in windows 7 (instead of windows 10) and everything goes fine. What could be the problem?. Not only fails me with model2, also with fusion and megadrive. I need your help :(
Juanjillu
« Reply #9 on: December 30, 2018, 04:42:47 am »
I FOUND IT!!! I found the fault !!! just click with the right button on top of the executable and in the compatibility tab, activate "DISABLE COMPLETE SCREEN OPTIMIZATIONS". I hope it will help someone else!
Zebidee
  • Trade Count: (+9)
« Reply #10 on: December 30, 2018, 04:59:34 am »
Thanks. Sorry nobody else was able to help. Think the crowd in here gets pretty thin over the festive season.
Juanjillu
« Reply #11 on: February 25, 2019, 12:52:50 pm »
hello good. After installing atom15, windows boots perfectly from the bios. But now when you run the groovymame what you see in the video happens. What can be? Regards!
Calamity
  • Moderator
« Reply #12 on: February 25, 2019, 01:00:18 pm »
Juanjillu
« Reply #13 on: February 26, 2019, 12:59:47 pm »
with the time I've been trying things ... THANK YOU !!!! ETERNALLY GRATEFUL!
