Author Topic: Audio connection quad amp to pc  (Read 3372 times)
pigjes
  • Last login:March 31, 2025, 12:44:05 pm
« on: November 28, 2018, 01:08:44 pm »
Hello,
I recently bought a San Francisco rush atari racing cabinet and am looking how to convert it to a multi game cabinet.
But,now I am unsure how to connect the atari SF rush quad amp to a pc for conversion.
In the wiring manual I see a connector labeled chin2 with connector pins for frontleft+ -, frontright +-, backleft +- and backright +-
But how would I go from the pc side to these 8 pins?
I could also omit the Atari amp and only use the wires going to the speakers, but which amp would I need to use to go from 4 speakers+sub to a pc soundcard?
Thanks for any tips.
landesmd
  • Last login:July 13, 2021, 05:05:19 pm
Re: Audio connection quad amp to pc
« Reply #1 on: November 28, 2018, 05:16:37 pm »
 :lol :lol :lol :lol  "I wish you were a beer" stamped on the bottom-right of the board!!
SailorSat
  • Last login:December 16, 2025, 01:58:00 am
    • For Amusement Only e.V.
« Reply #2 on: November 29, 2018, 10:40:03 am »
Mhm... The most easy solution seems to be setting your soundcard to 4.0 Sound, and then just use two 3.5mm headphone to 2 rca cables - that would give you the 8 required lines.
+ being the individual signal, - being the common ground
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
pigjes
« Reply #3 on: November 29, 2018, 01:10:03 pm »
Thank you for your answer!
I understand that the 2x 3.5mm to 2 rca cables would give me the 4 + ones (FL FR RR RL speakers).
But how would I connect (or from where do I get) the 4 common ground wires?
SailorSat
« Reply #4 on: November 29, 2018, 01:18:02 pm »
An RCA jack has two Connections - just connect the outer one (the ground) to each - input.
pigjes
« Reply #5 on: November 29, 2018, 01:23:19 pm »
Ahh I understand! Thanks again!  :applaud:
