Author Topic: Switchres error - Solved  (Read 1963 times)
Heian_Shodan
« on: November 25, 2018, 07:12:54 pm »
Can someone explain me whats happening here? Why I can have 120 hz when I set the native resolutions for games (384x240 on Capcom games, for example, but whatever I try to set the double resolution on the same driver, like 768x480 on 120 hz, I get the "could not find a mode that meet your specs error". Im using a 19' CRT which, according to the specs, is perfectly capable of outputting such resolution (aprox. 60 khz, when the maximum rate for my monitor is 96 khz). Why is that?  :banghead: :banghead:
Edit: Ok, I just figured it out. Can close it.
« Last Edit: November 25, 2018, 07:19:57 pm by Heian_Shodan »
