Author Topic: VMMaker modelines help  (Read 4834 times)
Sefirosu789
  • Last login:July 18, 2019, 10:28:47 am
« on: November 01, 2018, 02:00:34 pm »
Hi,
I am trying to get VMMaker to install the modelines for GroovyMame but instead of finding the 120 or so that other people get, mine is finding 1000. I am using the latest version of CRT Emudriver 2.0, latest MAME (203) version and latest Groovymame (202) version along with MAME 0.185 set (latest available).
Here is what is displayed on my VMMaker: (It has been like this for ages and its not doing anything else).
I read about having to enable "Magic" resolutions by changing a value in the VMM.ini file, specifically "mode_table_method_xml           1" to "mode_table_method_xml           2". However, this just makes VMMaker crash after I press generate modes.
Here is my VMM.ini file contents followed by my mame.ini file. Any help is appreciated!
VMM.ini:
Code: [Select]
mame_exe                        E:\Hyperspin\Emulators\MAME\groovymame.exe
mame_favourites                 mame_favourites.ini
mame_list_from_xml              1
mame_generate_xml               1
mame_only_list_favourites       0
mame_export_settings            0
user_list_modes                 1
user_modes                      C:\Users\Will\Desktop\crt\crt_emudriver_&_tools_2.0_beta_13_16.2.1_W.7.8.10-64\user_modes - super.ini
monitor                         arcade_15
orientation                     horizontal
rotating_desktop                0
total_modes                     auto
mode_table_method_user          1
x_res_min_xml                   240
y_res_min_xml                   240
y_res_round_xml                 16
x_res_min_user                  240
y_res_min_user                  192
y_res_round_user                1
dotclock_min                    auto
display_device_key              \System\CurrentControlSet\Control\Video\{F55095E7-576C-4163-BFB3-910584F0F514}\0001
auto_extend_desktop             0
edid_from_modelist              0
mame.ini:
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
homepath                  .
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini;ini/presets
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
pluginspath               plugins
languagepath              language
swpath                    software
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
rewind                    0
rewind_capacity           100
playback
record
record_timecode           0
exit_after_playback       0
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
snapbilinear              1
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
autosync                  1
sleep                     1
speed                     1.0
refreshspeed              0
# CORE RENDER OPTIONS
keepaspect                1
unevenstretch             1
unevenstretchx            0
unevenstretchy            0
autostretchxy             0
intoverscan               0
intscalex                 0
intscaley                 0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
fallback_artwork
override_artwork
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
beam_width_min            1.0
beam_width_max            1.0
beam_intensity_weight     0
flicker                   0
# CORE SOUND OPTIONS
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
verbose                   0
log                       0
oslog                     0
debug                     0
update_in_pause           0
debugscript
# CORE COMM OPTIONS
comm_localhost            0.0.0.0
comm_localport            15112
comm_remotehost           127.0.0.1
comm_remoteport           15112
comm_framesync            0
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ui                        cabinet
ramsize
confirm_quit              0
ui_mouse                  1
language                  English
nvram_save                1
# SCRIPTING OPTIONS
autoboot_command
autoboot_delay            0
autoboot_script
console                   0
plugins                   1
plugin
noplugin
# HTTP SERVER OPTIONS
http                      0
http_port                 8080
http_root                 web
# CORE SWITCHRES OPTIONS
modeline_generation       1
monitor                   arcade_15
connector                 auto
interlace                 1
doublescan                1
super_width               2560
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
vsync_offset              0
black_frame_insertion     0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# OSD KEYBOARD MAPPING OPTIONS
uimodekey                 SCRLOCK
# OSD FONT OPTIONS
uifontprovider            auto
# OSD OUTPUT OPTIONS
output                    auto
# OSD INPUT OPTIONS
keyboardprovider          auto
mouseprovider             auto
lightgunprovider          auto
joystickprovider          auto
# OSD DEBUGGING OPTIONS
debugger                  auto
debugger_font             auto
debugger_font_size        0
watchdog                  0
# OSD PERFORMANCE OPTIONS
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     auto
numscreens                1
window                    0
maximize                  1
waitvsync                 0
monitorprovider           auto
# OSD PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# OSD FULL SCREEN OPTIONS
switchres                 1
# OSD ACCELERATED VIDEO OPTIONS
filter                    0
prescale                  1
# OpenGL-SPECIFIC OPTIONS
gl_forcepow2texture       0
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl                   0
gl_glsl_filter            1
glsl_shader_mame0         none
glsl_shader_mame1         none
glsl_shader_mame2         none
glsl_shader_mame3         none
glsl_shader_mame4         none
glsl_shader_mame5         none
glsl_shader_mame6         none
glsl_shader_mame7         none
glsl_shader_mame8         none
glsl_shader_mame9         none
glsl_shader_screen0       none
glsl_shader_screen1       none
glsl_shader_screen2       none
glsl_shader_screen3       none
glsl_shader_screen4       none
glsl_shader_screen5       none
glsl_shader_screen6       none
glsl_shader_screen7       none
glsl_shader_screen8       none
glsl_shader_screen9       none
# OSD SOUND OPTIONS
sound                     auto
audio_latency             2.0
# PORTAUDIO OPTIONS
pa_api                    none
pa_device                 none
pa_latency                0
# BGFX POST-PROCESSING OPTIONS
bgfx_path                 bgfx
bgfx_backend              auto
bgfx_debug                0
bgfx_screen_chains        default
bgfx_avi_name             auto
# WINDOWS PERFORMANCE OPTIONS
priority                  0
profile                   0
# WINDOWS VIDEO OPTIONS
menu                      0
# DIRECT3D POST-PROCESSING OPTIONS
hlslpath                  hlsl
hlsl_enable               0
hlsl_oversampling         0
hlsl_write                auto
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_tile_mode     0
shadow_mask_alpha         0.0
shadow_mask_x_count       6
shadow_mask_y_count       4
shadow_mask_usize         0.1875
shadow_mask_vsize         0.25
shadow_mask_uoffset       0.0
shadow_mask_voffset       0.0
distortion                0.0
cubic_distortion          0.0
distort_corner            0.0
round_corner              0.0
smooth_border             0.0
reflection                0.0
vignetting                0.0
scanline_alpha            0.0
scanline_size             1.0
scanline_height           1.0
scanline_variation        1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
hum_bar_alpha             0.0
defocus                   0.0,0.0
converge_x                0.0,0.0,0.0
converge_y                0.0,0.0,0.0
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.0
offset                    0.0,0.0,0.0
scale                     1.0,1.0,1.0
power                     1.0,1.0,1.0
floor                     0.0,0.0,0.0
phosphor_life             0.0,0.0,0.0
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_jitter                0.0
yiq_cc                    3.57954545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_beam_smooth        0.0
vector_length_scale       0.5
vector_length_ratio       0.5
# BLOOM POST-PROCESSING OPTIONS
bloom_blend_mode          0
bloom_scale               0.0
bloom_overdrive           1.0,1.0,1.0
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.64
bloom_lvl2_weight         0.32
bloom_lvl3_weight         0.16
bloom_lvl4_weight         0.08
bloom_lvl5_weight         0.06
bloom_lvl6_weight         0.04
bloom_lvl7_weight         0.02
bloom_lvl8_weight         0.01
# FULL SCREEN OPTIONS
triplebuffer              0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# INPUT DEVICE OPTIONS
global_inputs             0
dual_lightgun             0
# FRONTEND COMMAND OPTIONS
dtd                       1
Zebidee
  • Trade Count: (+9)
  • Last login:Yesterday at 10:07:18 pm
Re: VMMaker modelines help
« Reply #1 on: November 01, 2018, 02:40:54 pm »
You'd better include some more info, like your PC, graphics card, OS.
Are you using XP?
I'm using XPx64 on core2duo 2.93 GHz with Radeon X1050 card, and I had a very similar problem with VMM crashing on generating modes from xml using GM 0.200 or vanilla MAME 0.200 or just plain mame0200.xml file. I reported the issue here, but nothing really happenned. However, I didn't/can't expect much because I'm using XP and nobody really wants to support XP anymore. I suspect that it is an incompatibility problem with xml generation/format in later versions of Mame (and therefore inherited by Groovymame too).
The only way I found to get around the issue was to use an older groovymame.exe (I used GM 0.179) to generate the mode list by xml.
BTW - there is nothing wrong with VMM creating 1000 or so modes, normally it will cull them back automatically, keeping the best ones
Calamity
  • Moderator
  • Last login:Today at 03:33:34 am
  • Quote me with care
« Reply #2 on: November 01, 2018, 02:45:03 pm »
Download CRT Tools version beta 14, that bug is already fixed.
Steps to create a log:
Sefirosu789
« Reply #3 on: November 01, 2018, 03:41:51 pm »
cut
Thanks for replying. It seems Calamity's fix made it work! You can try it now.
Thank you. It feels silly it was something that simple!
So now VMMaker looks like this after generating modes (pic 1 below). But when I open Groovymame, select game the "specs" menu appears (pic 2) but the game stays in 640x480 interlaced. I am guessing VMMaker didn't actually install the modes I want? Or perhaps a setting somewhere in Groovymame needs to be changed, but I can't find anything.
And my VMMaker MAME settings (in case that is the issue?) I don't know.
Thank you guys.
Calamity
  • Moderator
« Reply #4 on: November 01, 2018, 03:59:24 pm »
Magic resolutions (1234x) were used on XP, they're not used on 7 (don't work anyway). You don't actually have to parse MAME if you're already using super resolutions (2560x). Don't follow old guides. Just follow the ones linked in CRT Emudriver's download thread.
Despite that GM is working fine judging by the picture you posted. Keep in mind you're testing a vertical game.
Sefirosu789
« Reply #5 on: November 01, 2018, 04:29:41 pm »
Ok got it, yes I'm using the user_super.ini. I tried some other games and they were fine and non-interlaced. I looked at the modelist file and it appears that the 1941 game is meant to display interlaced.
Thank you Calamity. Now to try and get it GM working with Hyperspin which is even harder because no guides at all!  :applaud:  ;D
Zebidee
  • Trade Count: (+9)
« Reply #6 on: November 01, 2018, 08:58:20 pm »
Heh, I should've guessed as much! I'd better update my own setup. Thanks Calamity   :applaud:
