Author Topic: Nintendo Sharp Monitor 510YWB22 problems  (Read 2314 times)
General Zod
  • Last login:June 23, 2005, 03:58:28 pm
  • Banned
« on: February 07, 2004, 04:30:31 pm »
After a few weeks of collecting dust, I finally decided to do something with this monitor and connect her to my MAME testbench. ( if you want to call it that )   ;D
What a beautiful picture these Nintendo monitors have. Just the overall picture alone makes me wish I could forget about the problem I've encountered. Hopefully one of you can help me decide whats awry?
One a regular jamma board, and even connected to a real ms.pac cab, the picture is perfect. Nothing is cut from the top or bottom , however, when connected to my PC and through the Jpac ... all of the games are missing a little from both the top and bottom.
I'm using AdvMAME, an AVGA, and the jpac. Any ideas on how I can get this image to fit the screen properly. Perhaps a setting in AdvMAME? I know it's not the width coil or anything monitor-wise, because she works so beautifully with the other 3 games (uprights).
Any ideas ... please?
thanks.
« Last Edit: February 07, 2004, 04:32:59 pm by General Zod »
Ken Layton
  • Guru
  • Technician
Re:Nintendo Sharp Monitor 510YWB22 problems
« Reply #1 on: February 08, 2004, 12:07:30 am »
Looks to me like you need to adjust the width coil as your picture is too wide.
Also, the Sharp monitor's model number is XM-2001N. The number you gave is the picture tube number.
« Last Edit: February 08, 2004, 12:09:44 am by Ken Layton »
General Zod
  • Banned
« Reply #2 on: February 08, 2004, 09:58:25 am »
Thank you!
I was wondering whether or not the width coil was the problem. I had hoped it wasn't, as the other games played fine when connected to that monitor.
Adjusting the width coil from what I read, can be quite tricky. Any advice you can give from having worked on these? I would appreciate your input, and treat it like scripture.
Thanks in advance ,
Mike
