Author Topic: Ultimarc Ultimate io  (Read 5956 times)
councilface
  • Last login:June 28, 2021, 05:21:26 pm
« on: October 21, 2018, 05:37:38 am »
Hi apologies for the n00b question but I've been out of the scene for several years and want to make sure that I don't buy the wrong things.
I'm planning on building a pi powered conventional two player bartop using two Ultrastik 360s and have all 19 buttons lit using rgb LEDs (I may add a spinner too).
I see no reason why the ultimate io won't be up to the task, I just thought I'd check in case somebody knows something that I don't before I make the purchase.
Cheers,
CF
fablog
  • Last login:November 26, 2025, 06:59:35 pm
Re: Ultimarc Ultimate io
« Reply #1 on: October 21, 2018, 11:11:42 am »
I don't see any problem.
Do you need to play modern windows games? In this case you may want an encoder with xinput compatibility and this Ipac is not.
« Last Edit: October 21, 2018, 11:43:34 am by fablog »
councilface
« Reply #2 on: October 21, 2018, 12:45:07 pm »
Excellent, I think I'll be sticking to emulators unless there's some killer app that I'm unaware of. Maybe SFIV but that's probably in mame now, lol.
meduza
  • Last login:May 29, 2024, 02:10:17 pm
    • LEDSpicer wiki
« Reply #3 on: February 16, 2020, 12:39:40 pm »
If you are using retropie or other linux based OS, you will need LEDSpicer to control the LEDs part of the ultimate IO
check here for more details
