Author Topic: mm6 tube amp  (Read 2429 times)
baldnic
  • Last login:March 01, 2024, 08:29:17 pm
mm6 tube amp
« on: October 20, 2018, 10:24:36 pm »
my mm6 with tube amp  has developed a fault. when powered on it will blow the main fuse and trip the tube amp breaker. it has functioned great until the weather now turned cool in my temporarily unheated shop. what part is first to diagnose  and where should I start troubleshooting?
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: mm6 tube amp
« Reply #1 on: October 23, 2018, 07:12:05 am »
Hello Baldnic,
Check to 110 volt mains wiring to the amplifier for any shorts on the cable.
Check the amplifier for any obvious overheating of componants around the rectifying valve (or substituted diode pack).
The volages on the amplifier are going to be 300 plus volts DC so be careful, my avice is to send the amplifier to a Rowe Ami specialist to be tested/repaired.
Regards
Alan
Alan Hood
ami-man
UK
baldnic
Re: mm6 tube amp
« Reply #2 on: October 24, 2018, 08:07:00 pm »
Hello Alan,
Thank you very much for the advice. I'll do so and report back.
I appreciate all the information you've given out around here. Its invaluable.
Nick
Ken Layton
  • Guru
  • Technician
Re: mm6 tube amp
« Reply #3 on: October 29, 2018, 12:06:26 pm »
If the amplifier has NOT been rebuilt/recapped, I would advise you to send it off for repair rebuilding. Do NOT use that amplifier until you do so. Otherwise a shorted component in the amplifier can take out an expensive or hard to find power transformer or output transormer.
