Author Topic: "100%: I-PAC Ultimate (53769/140) not configured." using Retroarch issue  (Read 2297 times)
Azirithdorr
  • Last login:August 20, 2019, 06:10:06 pm
Hi all, thanks for reading!
Just recently got back into my arcade, and replaced my Ultimarc IPAC-2 with a Ultimate I/O. Did a fresh install of Launchbox and Retroarch.
Things are going pretty good, but one nagging thing that is happening is when I boot up an emulator, I get the following message:
From what I've been able to find, the advice is "go into Retroarch and shut off the warning". Do you agree with this? I'm curious what the warning even means.
The only other thing I've noticed is that only a few of my LED buttons are lit up once I'm in Launchbox. When I boot the PC, all the LEDs fade up and down in the preset pattern ( built into the Ultimate I understand ). But once in the frontend, only a few are lit and that's constant with no change - even after exiting the frontend. Could the error be related to this?
Again, thank you very much for reading and any responses - I appreciate it :>
boomerps2
  • Last login:October 17, 2018, 10:58:33 pm
Re: "100%: I-PAC Ultimate (53769/140) not configured." using Retroarch issue
« Reply #1 on: October 16, 2018, 06:09:38 pm »
I just got the i-Pac Ultimate for my LaunchBox setup and will be installing as soon as I get my graphics back. I have done a couple of Hyperspin builds with the Ultimate using Rocketlauncher and have never come across this message nor have I come across this message with the old i-Pac 4's with the LEDPac64 controller. Is this a LaunchBox only thing?
Azirithdorr
« Reply #2 on: October 17, 2018, 11:32:04 am »
I'm not sure - could be. I've only seen it when using Launchbox, but then again, that's all I use right now.
