Author Topic: San Francisco Rush: The Rock running @60fps in MAME  (Read 12234 times)
Bigtymer781
  • Last login:October 30, 2024, 08:10:04 am
« on: October 09, 2018, 08:00:57 pm »
I was messing around yesterday with the overclock slider controls in MAME and I noticed that if you increase the 'Screen Refresh Rate' the frames per second would actually increase slightly in Rush. When I put the refresh rate to the max value (67fps), Rush would top out at 34fps instead of 30, which is exactly half. So then I went into the MAME 0.199 source code and changed the max value to 120 to see if the game would then run at 60fps, and sure enough it did!
I was already using a custom MAME 0.199 build that had the main CPU for Rush (r5000) overclocked to get a frame rate boost, but the game would top out at 30fps. So then I started overclocking even more to try and get a solid 60fps. With the r5000 @600mhz (the default speed is 200mhz) I'm averaging 40-60fps. It's a pretty massive FPS increase over the default MAME, which goes as low as 15fps and probably averages 20-25fps.
It can be overclocked even more, but the higher the overclock the more demanding it is on your PC.
If anyone is interested here's a download link to the custom MAME 0.199 build...
https://www43.zippyshare.com/v/PDtDNsSY/file.html
When the game first starts you have to go into the slider controls menu (with cheats enabled) and set the 'Screen Refresh Rate' to 120fps.
Here's a video...
« Last Edit: October 10, 2018, 01:50:02 am by Bigtymer781 »
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
Re: San Francisco Rush The Rock running @60fps in MAME
« Reply #1 on: October 09, 2018, 10:26:20 pm »
Thanks for sharing. It's working great.  Hopefully the force feedback can be modified to work with this version and we'll have the ultimate version.
Bigtymer781
« Reply #2 on: October 09, 2018, 10:34:32 pm »
Yeah that would be great.
Here's 2 other versions that may work better or worse for some people based on their PC. The original link is r5000 @600mhz.
r5000 @400mhz...
https://www93.zippyshare.com/v/q6jOqzk9/file.html
r5000 @600mhz (original link)...
r5000 @1000mhz...
https://www53.zippyshare.com/v/U1YxGGQT/file.html
bandicoot
  • Last login:December 18, 2025, 12:30:46 pm
Re: San Francisco Rush: The Rock running @60fps in MAME
« Reply #3 on: October 10, 2018, 11:23:07 am »
Do you think it's possible to make somthing like that on GTI CLUB i think it's a similare problem
Bigtymer781
« Reply #4 on: October 10, 2018, 09:34:18 pm »
Is the game capped at 30fps? Maybe I could take a look at it sometime.
Here's some benchmarks I did today with fraps, they aren't very scientific because I couldn't figure out how to record input then playback input with MAME 0.199. During playback the inputs were out of sync, so I just played through the track four separate times for the benchmarks. Does anyone know if record/playback input is broken in the newer Mame versions?
Track 4 (Extreme Car) Benchmarks:
2018-10-10 15:29:22 - mame64 (200mhz @30 default mame)
Frames: 5639 - Time: 248416ms - Avg: 22.700 - Min: 15 - Max: 32
2018-10-10 18:17:44 - mame64 (400mhz @60)
Frames: 9874 - Time: 239259ms - Avg: 41.269 - Min: 30 - Max: 61
2018-10-10 18:04:29 - mame64 (600mhz @60)
Frames: 10945 - Time: 249789ms - Avg: 43.817 - Min: 30 - Max: 61
2018-10-10 18:11:14 - mame64 (1000mhz @60)
Frames: 11956 - Time: 244189ms - Avg: 48.962 - Min: 30 - Max: 61
These benchmarks were ran on an i7 8086k, and the emulation speed was locked on 100%.
« Last Edit: October 10, 2018, 09:39:10 pm by Bigtymer781 »
  • Last login:February 01, 2026, 01:32:52 pm
« Reply #5 on: October 10, 2018, 11:44:12 pm »
Yeah there are a few games with issues, like the crusin' series.  Might be worth looking into.
Boomslang
  • Last login:January 01, 2024, 08:20:43 pm
« Reply #6 on: January 05, 2019, 05:40:31 pm »
here ya go  ;)
Ive just added SF Rush The Rock stuff for this 60fps hack version (64bit)
I only used the original link you posted, not doing everyone lol
FFB won't work for any other mame games if using this specific version of mame, Ive only added SF Rush The Rock so if any other games are good with this then i can add others
« Last Edit: January 05, 2019, 07:53:21 pm by Boomslang »
DarthMarino
« Reply #7 on: January 05, 2019, 05:46:53 pm »
^Awesome. Thanks.  I've been playing a ton of 2049 since it got promoted to working.  It's probably worth revisiting the feedback on that game once MAME 0.206 comes out at the end of the month.
Boomslang
« Reply #8 on: January 05, 2019, 07:57:48 pm »
re-done it again cos someone said hack works on normal sf rush too so ive added that aswell now
I was hoping to add mame output support to ffb plugin sometime but no one seems interested to help on it and I myself don't understand it all so unfortunately it's gonna have to wait for now :(
I will eventually re-do the mame plugin cos firstly the code is a gigantic mess but secondly to update to newer mame but I'm thinking more like a yearly update rather then weekly or monthly
However if someone really wants to update quicker then I can show how to find the addresses easy enough and you can get list together and it's pretty easy for me after that
DarthMarino
« Reply #9 on: January 05, 2019, 08:11:06 pm »
Let's wait until 0.206 comes out and I might be able to help.
Bigtymer781
« Reply #10 on: January 12, 2019, 07:55:32 pm »
Cool man, thanks for adding it.
I haven't really messed with this or played Rush in a couple months, but there are two negative side effects from the overclocking that I'm aware of.
When the game first loads a scene in attract mode the emulation speed will drop below 100% and there will be a 'hiccup' even on fast CPU's. The other problem I noticed is on some tracks during the "3, 2, 1" countdown it will say "3, 1, 2, 1" something like that if I remember right.
They are pretty minor problems, but I think they both can be fixed (there are speedups for rush attract mode already in the source code). Also it would be nice if the refresh rate was set to 120hz by default (for Rush and Rush the Rock only), without needing to go into the config menu. I think these changes can be done in the future.
« Last Edit: January 13, 2019, 07:53:41 pm by Bigtymer781 »
BrownEye02
  • Last login:March 08, 2022, 11:00:09 pm
  • RUSH
« Reply #11 on: February 02, 2020, 06:19:30 pm »
r5000 @400mhz...
r5000 @1000mhz...
Any chance we could get a re-upload of these? The files have expired. :/
Never mind. Found your re-upload and google drive uploads from this thread, http://forum.arcadecontrols.com/index.php/topic,159908.msg1690705.html#msg1690705
For anyone else that comes hunting for the URLs like I did.
Here's a new version (MAME 0.209) that has the refresh rate slider hack.
https://www115.zippyshare.com/v/mXxU1Xff/file.html
In the future I want to have the refresh rate switch to 120hz automatically whenever a Rush game is loaded.
Yeah.
https://drive.google.com/open?id=1HCzYc15cKtwnhuzspMUm3amaLGNcot9u
« Last Edit: February 09, 2020, 11:14:47 pm by BrownEye02 »
