Author Topic: paint  (Read 960 times)
Yander
  • Last login:July 08, 2013, 08:00:14 pm
paint
« on: February 06, 2004, 10:57:09 pm »
what do you guys use to paint mdf lets say if i wanted it black how many coats of what?
orntar
  • Last login:November 18, 2010, 03:35:04 pm
  • boo!
    • neogeo.orntar
Re:paint
« Reply #1 on: February 06, 2004, 11:01:06 pm »
lots o prep is the key. sand it down, clean, primer, and sand again clean, primer, topcoat at least 3 thin layers. you'll get the idea as you lay down each layer.
you could even start on just one rear panel to get the hang of it.
i use rust-o-leum. for all of it. but it depends how pro you want to get. with good prep work average quality paint can look great.
« Last Edit: February 06, 2004, 11:02:29 pm by orntar »
- just say no to capitol letters -
TalkingOctopus
    • My Arcade
Re:paint
« Reply #2 on: February 07, 2004, 12:15:25 am »
I used 2 coats of primer on both the inside and outside to seal it.  Then I used three coats of black super satin paint with a roller.
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
Re:paint
« Reply #3 on: February 07, 2004, 11:01:26 am »
I've used two coats of water based primer.
I've already done one coat of paint and some parts are already with a nice finish ... I believe I'll only use two cotas of paint.
Note: I'm using a gun, not roller ...
Yander
Re:paint
« Reply #4 on: February 07, 2004, 02:01:16 pm »
thanks for the info.
