Author Topic: Need some advice on setting up Retropie/Attract Mode  (Read 5229 times)
« on: September 04, 2018, 10:55:15 am »
I have been trying to set up Retropie on a Pi3 B+ for a while now and I can't seem to figure it out.  I'm not looking to reinvent the wheel and I want the setup to be very simple - I could use some advice.
Here is what I'm going for:
General:
- I want to boot to the (only) gamelist using a momentary pushbutton.
- Remove boot up scripts and pi logo scrolling on screen.
- Replace splash screen with a custom one.
- Power off using same pushbutton at any time without having to go to "shutdown: in retropie.
- When selecting a game, need to read a config file to tell ServoStik to switch to 4/8 way mode (or stay where it is) [this part seems tricky]
Layout:
- No video snaps
- No "wheel" art (marquees)
- The list should show a screen shot of the game with the game name (with some minor art surrounding it).
- Up/Down to choose a game
- Start to launch game
- "P1 Start+P2 Start" to go back to list.
- No "emulator" level - this is an arcade only build so I don't need to "choose the system"
That's it!  Seems like it should be easy but I do not want users to have the ability to access menus and other settings.  Want to have to use a keyboard for that.
Should I start with a clean image of Retropie 4.4 and try to build it up from there or should I try and modify an existing image?  I downloaded a few and they are all way too busy and stuffed with way too many games.
Thanks!!
  • Last login:February 23, 2026, 12:46:16 pm
Re: Need some advice on setting up Retropie/Attract Mode
« Reply #1 on: September 04, 2018, 11:00:45 am »
Blanking out boot screens and adding custom logos is a complete waste of time. They only show up for a few seconds. Just setup the monitor to kick on 20 seconds after the Pi starts up.
As long as you are not writing to the pi when you shut it off you will be fine. If you are worried just keep a spare card with the same config on it. If your original corrupts after a million boot ups and shut downs, you can just slip the spare card in and be up and running instantly.
« Reply #2 on: September 04, 2018, 01:42:34 pm »
I didn't know you could delay the monitor display - that works too.  I don't want this thing to confuse anyone.  I just want it to work.
« Reply #3 on: September 04, 2018, 01:55:34 pm »
I wouldn't worry about a delay either. It is just more hassle. I am sure nobody is going to be confused at seeing a computer boot up. It is 2018 not 1956.
nitrogen_widget
« Reply #4 on: September 06, 2018, 10:35:10 am »
For my mini NES RPI console i just leave it on 24/7 hooked up to my hdmi switch on the big screen.
That way the kids don't have to futz with the power buttons.
If it were me i'd just turn it on when you expect people and just leave it on.
That way all they see is the game list when they walk up to it.
That's me though, retropie has very basic themes for emulation station and you can control the boot screen graphics.
As for text you can get rid of most of it.
There is a writeup about doing that in this section.
http://forum.arcadecontrols.com/index.php/topic,157745.0.html
Bottom of the page.
« Reply #5 on: September 06, 2018, 12:20:25 pm »
Bottom of the page.
Thanks for the link.  This is for a bartop that will likely end up in my son's room or in the basement so I'd prefer to not leave it on all the time.  I think what I'm going to do is install a clean image of Retropie 4.4, add the games and then build it up from there with functionality, layout, art, on/off, attract mode, etc.
