Author Topic: Jamma power wiring HELP PLEASE  (Read 1820 times)
flatoutjosh
  • Last login:October 16, 2018, 02:30:48 pm
« on: August 26, 2018, 03:09:27 pm »
hi
1st off im a total noob so please don't laugh and can u put things in real lame-man terms please!!
Ok so im building a 60 in 1 cocktail cabinet using a Jamma vertical board and a Wei-ya power supply,
ive used a female iec lead into the power supply and piggy-backed from that direct to the lcd monitor using a male iec lead,
ive ran the power in through switch and an in-line fuse holder with a 3.15amp quick blow fuse,
Ive come to power up today and im getting nothing at all (dunno if the power supply makes a noise when fired up but I got nothing and no LED on the pub board)
Im not sure if its wired wrong or not and im not very good with the electrics as this is my first project,
Can anyone direct me in any way/shape or form please?
  • Last login:Yesterday at 12:47:05 am
Re: Jamma power wiring HELP PLEASE
« Reply #1 on: August 26, 2018, 03:25:40 pm »
Can you provide some pics of how you have it set up? That would help us troubleshoot with you.
flatoutjosh
« Reply #2 on: August 26, 2018, 03:30:37 pm »
Heres a couple of the main wiring and to the fuse and switch
flatoutjosh
« Reply #3 on: August 26, 2018, 03:31:47 pm »
heres the others of the switch and fuse wiring (if any help)
Thank you!!
  • Bitches love Centipede
« Reply #4 on: August 26, 2018, 03:42:07 pm »
First... Do you own a multi-meter?
...but I suspect your switch is wired incorrectly.
« Last Edit: August 26, 2018, 03:44:09 pm by Nephasth »
%Bartop
flatoutjosh
« Reply #5 on: August 26, 2018, 03:43:41 pm »
I can acquire one yes
flatoutjosh
« Reply #6 on: August 26, 2018, 04:19:03 pm »
How do I check to see if it’s the switch please??
« Reply #7 on: August 26, 2018, 09:10:10 pm »
With the switch disconnected from any wiring, perform a continuity test. This will tell you which switch terminals have continuity in which switch position.
%Bartop
flatoutjosh
« Reply #8 on: August 27, 2018, 07:24:19 am »
Ok cool I will try that thanx!! Is the rest of the wiring correct?? If I know it’s down to either the fuse or the switch that eliminates a lot of work
