Author Topic: (SOLVED) Problem, Small vertical games on 24khz monitor.  (Read 5180 times)
xbrunox
  • Last login:Today at 12:28:39 pm
« on: August 17, 2018, 04:41:56 pm »
Hi all.
I have a problem of this type;
my cab is configured with a 24khz monitor  fixed on which I run almost everything in super resolution @ 2560 X 384 with orizzontal games all is ok and upscaled, but not with vertical games.
Vertical games occupy only a part of the screen probably because groovymame manages to center the 320 vertical lines in the 384 available and then the image is resized smaller.How can I do to ensure that the whole screen is occupied by the image of the game? And groovymame create a modeline with the correct refresh?
« Last Edit: August 22, 2018, 03:05:19 am by xbrunox »
xbrunox
Re: Problem, Small vertical games on 24khz monitor.
« Reply #1 on: August 22, 2018, 02:09:42 am »
Hello everyone!
I solved by changing the monitor string on  groovymame, and changing the minimum resolution that was 320 in 384.
