Author Topic: Megatouch Aurora touchscreen issues  (Read 5325 times)
jcmg24
  • Last login:July 26, 2018, 11:28:58 am
« on: July 25, 2018, 12:35:23 pm »
Hello
Cant calibrate my Megatouch Aurora 19”, the cursor goes in another direction…. Need help
is there a Driver...... usb driver ?
« Last Edit: July 25, 2018, 12:51:39 pm by jcmg24 »
mahkeymike
  • Last login:November 21, 2025, 04:40:35 pm
Re: Megatouch Aurora touchscreen issues
« Reply #1 on: July 25, 2018, 03:22:51 pm »
That video was published almost 1 1/2 years ago and you are finally trying to fix it? ???
lilshawn
  • Moderator
  • Last login:Yesterday at 11:01:31 pm
« Reply #2 on: July 25, 2018, 10:36:33 pm »
open front (2 allen screws on left and right top backside...security screw or nut on back middle top... #1 phillips on front top middle maquee) , remove monitor/overlay from front bezel (4 #2 phillips on left and right brackets) and tilt monitor up.
clean clean clean. 99% isopropyl.  make sure the gasket is intact and not touching plastic.
but it looks like a dead connection to a transducer.
in any case, if it still won't calibrate, you are looking at a new overlay.
http://parts.amientertainment.net/Products/?search=SB0533-01
mahkeymike
« Reply #3 on: July 25, 2018, 11:35:37 pm »
There is a lot of work involved in replaceing that overlay. I can replace the overlay and send you the monitor enclosure back ,if you don't want to tackle it yourself. You are looking at around $200 plus shipping. Consider that before you attempt it yourself, or decide to sell the machine. If you want to sell i am interested in that as well.
lilshawn
  • Moderator
« Reply #4 on: July 26, 2018, 12:58:17 am »
yeah... a lot of cutting...without hacking into your LCD panel
you should try it busted... with huge razor sharp chunks that make the utility knife you are trying to cut it off with seem like a butter knife.
probably why often sold the LCD and overlay as a single FRU part...
http://parts.amientertainment.net/Products/?search=SA0608-01
but good luck with that price...  ::)
