Author Topic: Getting rid of that text / terminal text when launching a rom from Attract Mode  (Read 9275 times)
mrclean
    • Guscade
Any one know how to get rid of the terminal text on the top that pops up when launching a rom ? It's extremely brief & only displays for maybe 1 second but ideally I want it gone. Sometimes it shows a mini paragraph more text than this example, sometimes it doesn't show anything if I relaunch the game etc... Any ideas on removing that terminal white text when launching a rom with Attract Mode ? :dunno
Example:
I launched a game text appears just prior to loading the game:
« Last Edit: July 17, 2018, 11:07:48 am by mrclean »
2,370,650 Gun.Smoke
mrclean
    • Guscade
is it within retroarch ? guessing it's this: mame2003-skip-rom-verify = "disabled" / if I switch it to enabled will that get rid of that text ? I don't want to start messing with config files until someone can verify.
2,370,650 Gun.Smoke
Marcoqwerty
  • Last login:January 04, 2026, 06:20:39 pm
Do you tried with custom loading image? are easy to do and maybe it helps to hide the terminal
https://github.com/retropie/retropie-setup/wiki/runcommand#adding-custom-launching-images
mrclean
    • Guscade
looks like it says:
failed to get vendor id of joystick /dev/input/js0
failed to get product id of joystick /dev/input/js0
[can't make out this garbage]
underneath that says something like :
working directory: /opt/retropie/supplementary/runcommand
2,370,650 Gun.Smoke
Titchgamer
Go into the retroarch settings then on screen settings, turn off on screen notifications.
Save and exit.
That should be it.
mrclean
    • Guscade
 Cool idea, but I didn't want to supplement it for something else rather get rid of it completely seems like popup ads redundant stuff lol not looking to do that, certainly didn't know about it & neat none the less... My Pi's are going in cabinets etc although like a brain washing polybius it would be great for me to inject an advertisement, DRINK YOO-HOO. However as an end user i'd be pissed to see that pop up every time I launched a game. Incorporating a logo / video intro when turning on the machine that's a different story.
Save and exit.
That should be it.
That's not it as it was already OFF. Still hasn't been resolved, any one else chime in ?
2,370,650 Gun.Smoke
behrmr
  • Last login:April 23, 2021, 09:17:13 am
Is this the arpicade? Just edit the launcher script and add “clear” command before and after. You may still see something but it won’t be for very long.
mrclean
    • Guscade
No as of now I'm using "Attract Mode" as a front end on the Raspberry Pi3b+ doing all of my testing outside of the cabinet not utilizing an ArPicade.
2,370,650 Gun.Smoke
mrclean
    • Guscade
***EDIT***
Finally FIXED this particular issue ! Using this thread on the Attract Mode Forums:
http://forum.attractmode.org/index.php?topic=1642.0
You need to replace what is in the autostart.sh script found in /opt/retropie/configs/all with
setterm -cursor off
stty -echo
clear
attract 2>&1 | grep -o $'\033\[2J'
You can just make sure that a # is in front of all the existing lines in you would rather save it in case you need to revert back.
Thank you need to make two text files one called runcommand-onstart and one called runcommand-onend.  They both need to contain printf "\033[H\033[2J"
Once you created them, rename them to add the .sh to the end and then upload them into the /opt/retropie/configs/all folder.
This can all be done via WinSCP but you can also do it via command line if you want
Pics of what I did to resolve:
My autostart.sh found within (opt/retropie/configs/all) picture below:
I created a .txt file as stated naming it  "runcommand-onstart" which contains:
Here is the other file named "runcommand-onend":
changed both of the documents / file type to .sh & placed them all in their respective folder using  WinSCP:
****MAKE SURE YOU RESTART / REBOOT To see it resolved... You must reboot / restart shutdown the pi etc and power up again etc.
2,370,650 Gun.Smoke
Marcoqwerty
Thank you to share it!  :notworthy:
