Author Topic: How to make this part of the stick thick so It hit's the Switches Together  (Read 3604 times)
sy7k
  • Last login:July 09, 2018, 06:29:50 am
My f+d,b+d,u+b and u+f buttons do not click together so I checked and this stick thickness was just an mm or 2 short to hitting switches together. I applied a rubber band and it was a temporary solution and it worked but the stick didn't feel right.Also tried tape but didn't work.Is there any adapter to thick this part ? Thanks  :dizzy:
« Last Edit: July 05, 2018, 05:49:07 am by sy7k »
  • Last login:January 30, 2026, 04:39:53 pm
What stick are you talking about?  Pics would help.  Sounds like you are using a 4 way joystick, not 8 way.
paigeoliver
  • Awesome face!
You have either a 4-way stick or it isn't put together right. The actuator flips over on some sticks to go from 4-way to 8-way.
However given which joysticks most people have been buying lately I am going to bet you simply have a 4-way stick.
sy7k
Attached the Images in the post,I use Img tag but sadly it is not working for me.
I think it's the Actuator, I will buy https://paradisearcadeshop.com/home/controls/parts/actuators/paradise-arcade/paradise-aluminum/762_oversized-jlf-actuator-set?search_query=Actuators+&results=41#
One of these ones but not sure of the size but I think  0.5 mm or 1 mm increase in width will do.
« Last Edit: July 05, 2018, 05:53:21 am by sy7k »
Rogue Trooper
  • Last login:August 17, 2021, 03:48:05 pm
You could try a bit of heat shrink to help increase the width. Just be very careful applying the heat with all the plastic parts around it. I would probably remove the part that you need to apply the heat shrink to so as to avoid damaging anything with the heat gun.
The heat shrink is relatively smooth and not 'grippy' like the rubber band so it may have a better feel. Also if it doesn't work, the heat shrink is easily removed with a sharp knife.
paigeoliver
  • Awesome face!
A quality 8-way joystick can be had for all of $10-$15. No need to do any weird rig job on that one.
  • Last login:January 29, 2026, 12:04:48 pm
It looks like a Sanwa JLF knockoff.  The original Sanwa restrictor (sometimes called the gate) has a center section that can be rotated to switch between 4 and 8 way.
Not sure if yours does or not.
paigeoliver
  • Awesome face!
Right, so the original poster has a chinese trash stick. Don't waste money trying to upgrade it, just buy a real stick. Genuine Sanwa JLF if you watch Anime, Happ Super otherwise.
05SRT4
  • Check out my Pow Pow
This was already being discussed in OP's first thread. http://forum.arcadecontrols.com/index.php/topic,157627.msg1656607.html
I agree with the joystick selection. The time and effort you are putting into a cheap AliExpress kit could be avoided if you bought a brand name stick from a reputable manufacturer/distributor.
sy7k
Thank you all for your inputs, I will be saving up for a genuine Stick. Lesson learned.  :applaud:
wrap the actuator in electrical tape until you replace it.
Its a trash fix for a trash stick, but it'll be a serviceable band aid
  • Last login:January 29, 2026, 09:23:52 am
If you need some financial planning advice to save up 15 dollars just let me know.
barrymossel
  • Last login:October 29, 2021, 11:25:52 am
  • Spectrum
Ghehehe, you are such an ass. Funny, but an ass...
