Author Topic: Help needed with Taito Type X games setup  (Read 5587 times)
tonythewrench
  • Last login:May 22, 2023, 08:24:51 am
« on: June 11, 2018, 06:33:14 pm »
I am having a few issues setting up some Taito type x games, namely King of Fighters Maximum Impact Regulation A...it crashes after the intro video, unless I insert a credit before the intro starts, then it will go to the start screen.  Is there a fix to the intro crash or is there a way to make it insert a credit right after launch to stop the intro video crash?
Also on a related issue, with Daemon Bride I have it working fine except I need to exit twice when I run it through hyperspin...the first time I exit it closes the game and returns to hyperspin menu, but leaves command line open of the game which then relaunches the game and I have to exit out a second time...similar to how I asked about KOFMIA, is there a way to tell hyperspin/rlauncher to exit twice?
These TTX games seem to have their own little glitches and needed tweaks but once they are worked around I find these titles are well worth the addition to anyone’s cabinet! Any help/advice is much appreciated
Titchgamer
Re: Help needed with Taito Type X games setup
« Reply #1 on: June 12, 2018, 03:52:13 am »
TTX games are a ---smurfette--- to get set up and working!
Think I took like a week just doing them!
Anywho I never experienced your exact problem but you could maybe run a AHK script to dump a credit in if you run it the same time as the game?
tonythewrench
« Reply #2 on: June 12, 2018, 08:26:10 am »
Do you have any idea how to do such an AHK script, or can you direct me to a tutorial?...yeah ttx can be a headache, took me a few days to figure out which programs had to be put in compatibility mode and which ones run fine without...can’t say enough about how much I dislike windows 10
Titchgamer
« Reply #3 on: June 12, 2018, 09:15:37 am »
Just put ahk tutorials in google.
To have it do 1 button press is very simple :)
Moksi
  • Last login:March 17, 2025, 08:13:58 am
« Reply #4 on: June 27, 2018, 04:52:59 am »
You need to use Game Loader All RH for that game it doesnt work well without it
tonythewrench
« Reply #5 on: July 09, 2018, 08:12:28 am »
Thanks for the tip Moksi, it worked...(took me a while to find a download that wasn’t full of malware) I found that Game Loader All RH makes other games I already had working run much smoother too!
