Author Topic: Issue with spinner and 720  (Read 2324 times)
martin35
  • Last login:August 19, 2021, 09:55:29 am
« on: June 11, 2018, 10:28:10 am »
Hello Guys
I’m experiencing a problem with the spinner and 720 on my mame cabinet.
I use to run my cabinet with an old dual Core processor from around 2008 running MAme 181 and everything was running great until it dies last week. As a backup I’ve installed an even older Pentium4 with Mame 141. It works ok but I have a problem with 720. The spinner work but I’m only able to spin the skateboard 180deg at a time, there is nothing in between. I wonder if it’s mame version issue and if so, which is the oldest mame version without that issue ?
Hopefully there is a 720 guru out there able to help me
Thanks for the help
Martin
DarthMarino
  • Last login:September 06, 2025, 02:38:47 pm
Re: Issue with spinner and 720
« Reply #1 on: June 11, 2018, 01:41:05 pm »
At some point they changed the way the controls are handled in MAME.  How do you have it set in game configuration?  I have a youtube video on the various control settings in MAME if you need help with it.
martin35
« Reply #2 on: June 11, 2018, 01:51:25 pm »
Great. I will look at it tonight
Thanks a lot
Martin
paigeoliver
  • Awesome face!
« Reply #3 on: June 11, 2018, 06:06:18 pm »
Also it will never be RIGHT, without the RIGHT controller. The right controller has a special encoder setup so that one spin of the wheel is always one spin of the skater and whichever way you face the handle the skater faces that way.
martin35
« Reply #4 on: June 12, 2018, 06:28:21 am »
Thank you Darthmarino, your video is very informative. I've did some test yesterday and it looks like I have a rom VS Mame version issue. Stangely I cannot open 720 directly with mame( I got a missing rom error message) but it works thru Maximus....
Like I said it works but when I push Tab I have a really limited menu where I cannot change the controler type. I've tried with different rom version with the same result.
I will probably wait to have a better PC to reinstall a more recent mame version unless you have another suggestion
Thank you your help
Martin
paigeoliver
  • Awesome face!
« Reply #5 on: June 12, 2018, 12:38:54 pm »
720 has been working in mame for like 17 years, latest version is not going to be your fix.
martin35
« Reply #6 on: June 12, 2018, 02:34:24 pm »
Interesting, I will try to dig a little deeper.
Martin
