Author Topic: Help on urethane sanding?  (Read 3958 times)
Fonkybeachbum
  • Last login:September 27, 2023, 12:10:14 pm
« on: May 28, 2018, 01:47:04 am »
Hello, So I had painted my boxes and put on the first coat of urethane and came home and put some 220 sand paper on and it totally f'd it up.  400 did the same thing where white came out and totally ruined the job.
https://imgur.com/gallery/7cOqFss
bperkins01
Re: Help on urethane sanding?
« Reply #1 on: May 28, 2018, 08:33:29 am »
Whats the question?
It looks from the picture that you have a bit of orange peel.  Sand with the 220 grit until smooth and the scratch pattern is uniform.  You need to use a sanding block for this..
Once the pattern is even, put on another coat of paint..  the idea is for it to be smooth of course..
The finish coat should not be sanded.
Fonkybeachbum
« Reply #2 on: May 28, 2018, 09:37:39 am »
Thanks for the reply.   So I do what you say and then put on another coat of URETHANE and the scratches will go away?  I was a couple drinks deep when I wrote last night.  To be clear I had already painted, sanded, painted, put on the first coat of urethane, and then started to sand with 220 when this happened.  The box actually had looked pretty good before I sanded the urethane coat, but was trying to get it perfect and just following all the instructions I had read.  I wasn't expecting the urethane to scratch up so much when sanding, but I'm a complete novice at finish painting.
Fonkybeachbum
« Reply #3 on: May 28, 2018, 11:35:52 am »
To answer my own question, I put a little urethane over the sanding and the orange peel went away.  Thought I was messing all the work up, but all looks like it will be ok...thanks for the help.
