Author Topic: How many admin buttons do I need? (Trying to fit 4-player setup on Ultimate I/)  (Read 13053 times)
obizues
  • Last login:June 11, 2023, 06:17:35 pm
  • Before you start your next project, don’t.
This is my current layout:
  • Last login:Today at 04:39:00 am
obizues
0
You should be happy I'm trying to get rid of buttons!  Which admin would I need because "Pause" and "Exit" - and how many buttons do most 4-way games use?  am I okay with 2?  Do I need more?
 :hissy:
  • Last login:February 15, 2025, 12:57:26 pm
  • Bitches love Centipede
READ PROJECT THREADS
%Bartop
obizues
I’VE BEEN SEARCHING AND READING THEM BUT I HAVEN’T COME UP WITH A SOLUTION FOR HOW MANY BUTTONS ARE NEEDED FOR 4-WAY GAMES.
Mike A already told you. 0.
%Bartop
  • Last login:Today at 01:45:23 am
Word of advice, just buy your parts and start putting it together. That’s the best way to learn how to do any of this stuff. Yeah, you might have leftover parts but that’s OK.
You can do all the reading you want, but until you start physically building a cab, it’s all just clouds in the sky anyway.
No more than two for any of the good ones.
obizues
Mike tells me I can play games on an etch-a-sketch.
Do you not know the answer?  I know there even was a 4-way game with 4 buttons.  But I don’t know if that is the exception.. I think it would. I can think of a bunch of one-button, and some 2-button..  but my memory on these is limited and I can’t seem to find any lists.
obizues
Awesome!  Thanks!
Is there any need for more than a “pause” and “exit” button for admin controls?
Awesome!  Thanks!
You’re asking the wrong person. I am Mr. “No admin buttons are needed, period.”
  • Last login:Today at 08:25:01 pm
(PROTIP: Read the whole FAQ.  It's there to help you.)
keilmillerjr
  • Web Developer.
05SRT4
  • Check out my Pow Pow
Do people actually pause arcade games?
I usually only have a Exit button.
Moneyhead
  • Last login:January 15, 2024, 03:36:32 pm
2 Buttons.
"Exit" and "Credit" (one is enaugh even for 4 players for most games).
In theory you won't need any. But that's not idiot proof. I have a machine with 0 buttons in our pinball club.
There is a big sign explaining how to add credits and exit a game. But nobody ever is reading that.
Zipper
  • Last login:May 11, 2024, 09:49:36 am
  • I've Built My Own Arcade Controls!!
0 admin buttons, and 0 buttons dedicated to a 4-way stick (no dedicated 4-way stick, imo).
Use the shift function that all decent keyboard encoders come with to do all the admin. By default the ultimarc stuff will let you pause, exit, adjust volume, add credits... all without admin buttons.
Use sticks that have a switchable 8/4 way gate.. a lot of 4-way games play fine in 8 way mode, but some are bad with diagonals. I put trackball in the same category as spinner, guns, yoke, tron stick etc.. Not something I'd sacrifice the a tidy panel to accommodate to be honest. If others are using my cabs, then they can ask me how to change game and I'll do it for them. You can always have the start buttons also = credit buttons, if you don't want to explain how to add credits and you have no coin mech.
I've got a 4 stick panel on my sega cab, and it's busy and cramped enough with 16 buttons:
tip you may have heard before - Don't mount your sticks at an angle, keep Up pointing due North on all sticks.
Moneyhead
Quote from: Zipper
In real live the shift function is only good for single player games.
Shift is on "left start" on the ipac.
So you have died in a multi player game, pressing "Start" while the other players are still mashing some buttons, sometimes ending up in the Mame menu.
I have reprogrammed my jpacs to remove all shift-functions.
Zipper
Quote from: Zipper
Exit (P1+P2 start) is the only combination that could use changing if you have button mashers that get through credits quick (I've found). Once I mapped it to P1 start + P1 B2, then all the shifted functions are on P1 controls, and it doesn't matter what the other players are mashing. I understand why people would want a dedicated Exit button instead, it's just not for me.
I love you <3  Also, that Sega panel looks great!
P1 and P2 start to exit can cause issues but I don't think it happens as much as people assume it will. In all the time I've played on MAME cabs with IPACs/shifted keys, its literally only happened to me once.I blame Sengoku 3 for being a credit muncher.Luckily I had saves states enabled! I know anecdotal evidence is not data, but I am just conveying my real world experience. If you MUST have admin buttons, EXIT is the only one I could remotely justify. I can only justify it because kids slam buttons at random. Everything else can be shifted with little to no impact (I disable the shifted shortcut for tab on buttons)
I also agree with Yots, planning everything out is great but when you start to actually build things you get a much better visualization of everything.  Make your first flight deck control panel out of cardboard.
DrakeTungsten
  • Last login:August 14, 2022, 06:36:45 pm
  • I effed with the wrong person!
    • No Quarter - a basic FE, WIP
The OP asked a single question which really should have been two distinct questions, and that's leading to a bit of confusion or frustration for the OP. Question 1) Which admin functions should I have? Question 2) What is the best way to map these funtions to my control panel?
I'm doing fine with just a dedicated Exit button and a dedicated Pause button. Both are a little out-of-the-way, and these buttons are the least of my problems when other people use my cab.
« Last Edit: May 18, 2018, 09:13:57 am by DrakeTungsten »
Only the console kids need to pause...
%Bartop
Where can I get one of these?? It looks great! Would be awesome for the nieces.
DrakeTungsten
If life has a 5-10 minute intrusion coming your way, it doesn't much care whether you're playing an arcade game or a console game.
« Last Edit: May 18, 2018, 09:41:05 am by DrakeTungsten »
OP:
I've got two MAME cabinets.  One has admin buttons the other uses shifted-buttons.  When we have parties I never have to help folks use the cabinet with admin buttons.  With the other cabinet people occasionally get confused or exit a game by accident.  Not really a huge deal but something I have noticed.  Having said that I'm happy with the layout of both cabinets and certainly wouldn't add admin buttons to the one without because it would clutter up that CP.
obizues
:laugh2:
obizues
My 3 month old daughter begs to differ.
obizues
OP:
Thanks for the feedback. Your comment of others not knowing how to use it is my main concern. I definitely don’t need more than two though it seems.
  • Last login:September 15, 2025, 10:44:52 am
If you have kids it is a necessity.
I have 4 admin buttons on all of my cabs.  P1 Start, P2 Start, Exit and Pause.  I wire coin rejects for the coin button.
4 player cabs are a waste of real estate, IMO.  There is Simpsons, X-Men, TMNT, etc. which are all the exact same game with different skins and then Gauntlet.  All of these games can be played with 2 players and getting 4 people together to play seems like a once a year thing, if that.  I don't know - maybe I'm missing out but I can't justify an aircraft carrier runway sticking out of a cabinet and taking up space in the room.
Start buttons are not admin buttons.
%Bartop
 ;D  I've always called any button that's not an in-game action button an admin button... so I guess I only have 2!  And could easily eliminate Pause and go down to 1 but if I was going to do that I'd shift 2 action buttons for Exit and go down to 0.
So Mike was right.  0 admin buttons.
I’m not chasing world records, so if I need to walk away from the game, so be it. I’ve never understood this compelling need to pause. It’s not like I spent a quarter anyways.
« Last Edit: May 18, 2018, 11:27:11 am by yotsuya »
Well if you’re building for kids and casuals, pause is fine. There are games like Simpsons and Xmen that are just quarter feeders anyway, it’s nice to be able to pause those games since it’s not about score and more about completion.
On the topic of searching for answers, I just did a search for admin buttons in the main forum (go to Advance Search and select specific areas of forum) and a slew of threads show up just like this, with similar answers.
I suggest you use the advance search function and put in the time investment of reading. Not only will you get your answers but you’ll get even more knowledge and tips along with it.
Zipper
It’s a panel from a Sega Swing. There aren’t many generic 3/4 player cabs around so I really wanted one. They do turn up occasionally.
Someone questioned how many games need (allow for) more than 2 players... well there are dozens. Including loads of my favourites like moonwalker, captain commando, undercover cops, Cadillacs and Dinos, Battle Circuit, rampage, alien vs pred, golden axe troda, Sega spiderman. There are loads - not just fighters (although mainly!). I like gaming with all my kids together.
Nothing wrong with going for 4p on a panel, but to a lot of people they are going to be ugly/messy and there’s nothing anyone can do about that. Keeping things minimal will appeal to more people. My panel has been called a surfboard, and I’m not going to argue.
Build what will make you happy and enjoy the games. You’ll have a blast making it. But in my opinion, when it comes to panels less is more. And admin buttons, dedicated 4-ways, spinners, trackballs, yokes... they all take more away from the panels aesthetic than they add to its function / enjoyment.
« Last Edit: May 18, 2018, 03:30:06 pm by Zipper »
barrymossel
  • Last login:October 29, 2021, 11:25:52 am
  • Spectrum
That makes no sense. If I play, I play to win. And if I have to walk away I won't "win" if I can't pause.
Sweep the leg Barrymossel.
The world won't end if I have to walk away from my game.
« Last Edit: May 19, 2018, 07:43:29 am by Mike A »
DrakeTungsten
Whereas if you work for NORAD and you get some really critical wires accidentally hooked up to your pause button, the world *could* end because you decided to add a pause button to your CP, but this seems unlikely. Still, better safe than sorry!
« Last Edit: May 19, 2018, 11:36:01 am by DrakeTungsten »
DrakeTungsten
yeah, nobody was  talking about going for world records except yots, but I'll bet lots of us go for our personal best (why wouldn't he want to address this obviously more common scenario?). I can see the point that if you pause the game, even if you do so because you have an emergency to attend to, you're still getting a break, which wouldn't make you current run really comparable to any of your other runs. On the other hand, you could get knocked out of your groove during the pause, and so if you beat your PB after the pause, it could be despite the pause and not because of it. On the third hand, it's just a video game, and you don't owe anybody any explanations as to whether or not your high sores came from a session in which you paused the game.
JDFan
But playing to win would normally include not cheating in the process -- and a part of winning would mean overcoming fatigue and loss of mental focus -- Pausing the game so that you can rest or refresh your mental state will change the overall outcome of the game.
Beautiful candy cab! I haven’t seen a Swing before, didn’t know they had Japanese cabinets that support 3/4 players. Great stuff!
