Author Topic: Speakers for MAME?  (Read 4301 times)
obizues
  • Last login:June 11, 2023, 06:17:35 pm
  • Before you start your next project, don’t.
Speakers for MAME?
« on: May 09, 2018, 10:40:03 am »
What kind of speakers do people recommend for MAME machines?  I’d also like to control the volume from the front of the cab easily on the front face of my CP if that changes things...
proplayer77
  • Last login:November 09, 2019, 03:23:58 pm
Re: Speakers for MAME?
« Reply #1 on: June 09, 2018, 04:49:14 am »
Sky is the limit. You can use 2.1 speaker set or a arcade amp with 2 channels on 4 channels where you can (i suppose) put the 2 channels in cross for bass.
I myself use a arcade 2 channel and 6.5” 60w car speakers on my project(4Ohm) but any speakers will do.
All depends on how much you want to put time, effort and money for it.
Im think going to install my amp inside the kb/mouse drawer, because making it visible could be complicated.
  • Last login:Yesterday at 05:17:02 pm
« Reply #2 on: June 09, 2018, 05:12:51 am »
The speakers will be about a foot from your face. 99 percent of classic games were not in stereo. 1 6x9 speaker with a small amp will get loud enough to make your ears bleed. The PC in my MAME cab combines the stereo signal into one channel. That way you get all of the sound even from stereo sources. Of course with some of these widescreen cabs two smaller speakers would look better.
Ignem
  • Last login:September 30, 2018, 05:24:21 pm
« Reply #3 on: June 21, 2018, 09:32:31 pm »
What do people do for a mechanical/hardware volume control if you're using a car amp and speakers?  Also, how would I power the amp, is it possible to do that from my PC's power supply?
