Author Topic: Bartop Marquee Retainers?  (Read 1822 times)
rhoelsch
  • Last login:August 18, 2018, 08:13:16 pm
  • That...that thing's operational!
« on: May 03, 2018, 04:59:53 pm »
The bartop is a small 1-player, only about 10 inches wide. The mdf I'm using for top of cab & bottom of marquee is 1/4" (5mm). It's been hard to find a good option because of the smaller scale. Also need to figure a solution for supporting my bezel plexi. Maybe just screwing into thin wood supports?
Now witness the power of this FULLY OPERATIONAL Mame machine!
Jakobud
  • Last login:December 09, 2025, 12:11:34 pm
Re: Bartop Marquee Retainers?
« Reply #1 on: May 05, 2018, 01:03:20 am »
You are going to want a pair of marquee retainers:
https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR2.TRC1.A0.H0.Xjazz+g1.TRS0&_nkw=marquee+retainer&_sacat=0
They typically come in a 2 pack, one of the top of the marquee, one for the bottom. These are typically made for a full size cabinet but they should still work just fine for a bartop. They are plastic so you simply cut them to length (10 inches in your case) and then simply drill a few screws through them to mount them in place. Couldn't be easier. Also they are very affordable.
ivwshane
    • My first mame cab! (WIP)
« Reply #2 on: May 10, 2018, 12:05:59 pm »
I like to use angled aluminum. Its easy to work with (use the same tools you would for wood) and its readily available at your local home improvement stores.
