January 30, 2026, 03:05:06 pm
Any way of ordering a customize button layout?
I would be happy with just buying the case, without the PCB. Heck, I'd take a case without any holes and drill my own TBH. I don't even need the joystick mount, since I'm looking to put a pinball stick together for some pinball video games.
Quote from: opt2not on April 25, 2018, 01:26:40 pmAny way of ordering a customize button layout?Hello..Sorry but it is not possible for now. Bfs it is not the pcb only problem. Metal case is not allowed to change panel layout.
Ahh - from the looks of the first pic it should be simple to replace the top with a sheet of aluminum/metal - Looks like the top panel is just mounted on with 4 screws on the edges so pretty much any sheet metal panel could be cut to fit and 4 holes drilled for the screws ( maybe add a vinyl overlay to cover the metal if you can't get the paint to color match the rest. )EDit : Actually the top panel is not just a plate but part of the box ( see the second video posted) - but you could change it up by cutting the top to remove it from the areas your layout needs and adding a panel over the top like the plexi overlay they are using - so would be workable just a bit of cutting and modding to it.
If you don't need metal, we can work something out with wood. I have a CNC machine with a 24 inch x 12 inch work area. I can technically work with aluminum, but I have never bothered with it.
