Author Topic: minimum power required for a JVS?  (Read 2043 times)
gique
  • Last login:April 25, 2018, 10:07:51 pm
  • I <3 my egret
« on: April 23, 2018, 09:23:48 pm »
Hi, I am doing a little software R&D on controller I/O.
I am wondering if I can power a JVS without resorting to an arcade power supply so I can make a compact desktop setup for my experiments without using my arcade cabinet.
I`m not using jamma boards at all - the set up would be like this.
PC -> JVS -> JAMMA-> REWIRED CONSOLE JOYSTICK
the only thing needing external power in this setup, after the PC of course, would be the JVS, so I am assuming I could wire up a mains adaptor to the JVS via the jamma harness or CN7 +5V, although I am unsure if this is IN or OUT
So I wanted to know how much power Sega and Taito JVS units use, and would this idea be safe?
« Last Edit: April 24, 2018, 03:33:17 am by gique »
paigeoliver
  • Awesome face!
Re: minimum power required for a JVS?
« Reply #1 on: April 25, 2018, 07:44:17 pm »
If you are just running an I/O board then your PC power supply can handle the overhead just fine. If you are actually plugging in real boards then you will need a separate power supply.
gique
  • I <3 my egret
« Reply #2 on: April 25, 2018, 10:07:51 pm »
Thanks for the reply.
Yes, just the IO board.
I am looking for a more portable solution than wiring a JVS to my PC power.. hence my potential idea of a mains adaptor..
Does the JVS need both 5v and 12v just to run?
paigeoliver
  • Awesome face!
« Reply #3 on: April 26, 2018, 10:27:38 pm »
The IO board does not need the 12 volt hookup, just the 5 volt.
