Author Topic: Wiring Help! Mega touch controller powered by a PC wiring knowledge needed  (Read 4790 times)
Garth2013
  • Last login:April 14, 2018, 03:20:07 pm
Hi All,
Firstly, apologies but i am a noob at wiring so i will likely ask simple questions. Long story short, i nought an old Megatouch Force quiz machine which did not work (which i knew) so i have taken all the parts out and fitted an old PC. My issue is that i need to wire in the 3M touch screen controller and the audio amplifier in to the PC wiring but i have no idea how to do this!
Any help is appreciated! I can upload pics if needed but i have googled it to death but dont seem to find the information i want
Thanks,
Gareth
Titchgamer
Some pics of what you have and what you want to connect will help.
Garth2013
Hi, sorry see uploaded!
Garth2013
So the first set of pics is the touch screen controller, the 2 wires and the PC. These pics are for the amp which needs a 12v supply
you could skip the amp and just use PC speakers, but if you want to power the amp just get a MOLEX splitter and tap the yellow for +12V and the Black as ground.
Garth2013
Thank you. Stupid question alert.....i get the splitter, should have some from old PC units but how do I then wire the splitter to the amps 2 wires (which I assume are live and earth)
I have considered the PC speakers and even tried them but the quality isn't great and I'm doing all this on a budget of what I own already! My main issue is the touch screen controller wiring, if I can't get that to work the project is a bust!
orizzle
  • Last login:September 21, 2020, 07:20:41 pm
He just told you....yellow is 12v, black is ground
you cut the end off one of the splits, yellow is your "live" +12V and black is your ground. Its not an Earth ground, just a ground.
