Author Topic: Marquee retainer  (Read 5285 times)
Brandon101884
  • Last login:March 01, 2020, 03:06:14 pm
Marquee retainer
« on: April 08, 2018, 05:22:29 pm »
I’ve been building Bartop Arcades and have always cut in a notch on the top and bottom of the marquee support with my table saw so the marquee slips right in. I wanted to try something new so I purchased some of those marquee retainer clips from suzo Happ. Well, they arrived and I have no friggin clue how to use them.  I may be just over thinking it. Is it as simple as laying the flat part on on the under side of the marquee section and the curved piece facing upwards so it holds the marquee? I must be missing something.
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
Re: Marquee retainer
« Reply #1 on: April 08, 2018, 06:07:26 pm »
That is it, except you need a piece on the top as well.
Brandon101884
« Reply #2 on: April 08, 2018, 07:15:34 pm »
Dang, I figured that was it. Doesn’t really leave room for tmolding. What does everyone here do to keep their marquee in place?
  • Last login:July 27, 2025, 08:34:04 pm
« Reply #3 on: April 08, 2018, 10:42:23 pm »
1/2 inch lath screws
  • Last login:July 11, 2025, 09:17:44 am
« Reply #4 on: April 16, 2018, 12:03:39 pm »
For a Bartop I'd just use these.  Drill pilot holes for the screws.  Spray paint them black from the inside.  The clear outside will make them look great.  They are dirt cheap at Lowe's or Home Depot:  https://www.lowes.com/pd/Miller-LLC-48-in-Plastic-Corner-Guards/1184387
I have these on my Vigolix builds:
DeL
EMDB
  • Project RetroCade
« Reply #5 on: April 16, 2018, 01:15:18 pm »
I used poster strips. They are very cheap and commonly available:
You can just bend then to have the correct angle, drill some holes to mount them and your done  :applaud:
JS94
  • Last login:May 03, 2018, 08:38:10 am
« Reply #6 on: April 16, 2018, 05:05:57 pm »
please post more pictures of your arcade.  i'm looking for ideas for my marquee and i love the green piece.  thanks
« Last Edit: April 18, 2018, 03:08:10 pm by DeLuSioNal29 »
paigeoliver
  • Awesome face!
« Reply #7 on: April 16, 2018, 06:30:57 pm »
Bartop cabinets are not supposed to have marquees, they are designed to be a low as possible so you can still see the bartender and the bartender can still see you.
barrymossel
  • Last login:October 29, 2021, 11:25:52 am
  • Spectrum
« Reply #8 on: April 17, 2018, 01:52:17 pm »
Isn't that just clear plexi without marquee art?
EMDB
  • Project RetroCade
« Reply #9 on: April 17, 2018, 03:25:21 pm »
Off topic: If you quote you should remove the images!  [fixed by mod.]  :afro:
On topic: Why don't you click the links in my signature!?
« Last Edit: April 18, 2018, 03:08:37 pm by DeLuSioNal29 »
EMDB
  • Project RetroCade
« Reply #10 on: April 17, 2018, 03:26:13 pm »
Yes  :cheers:
