Author Topic: newbie needs advice  (Read 4651 times)
Brian
newbie needs advice
« on: June 14, 2002, 09:31:20 am »
Hello all.  I am attempting to plan out a cabinet and need some advice from the experts.  After reviewing most of the examples on this site, i see many folks using 2 8-way joysticks AND a 4 way.....
     1a.  Is using a 4/8 way switchable stick really that horrible where a dedicated 3rd stick is needed?  Hoping to free up cp space for a trackball, need to know before I order parts....OR
      1b.  If a dedicated 4-way joystick is the ONLY way to recreate pac-man, DK, etc, does the I-PAC need to be reconfigured to recognize when the 4 way is used??  (sorry if i sound confused, but if you wire up your 8ways to the default MAME 1 and 2 player up/dn/l/r, where do you wire in the 4 way joystick??
       2.  Opinions on best tv out video card support?  Hoping to run MAME32 with windows, maybe arcade fx.
Thanks, Brian in Buffalo (sorry if long winded)
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
Re: newbie needs advice
« Reply #1 on: June 14, 2002, 10:21:37 am »
8 way sticks don't "feel" like 4 way sticks. As you move the stick quickly from left to up (for instance) it has a tendency to keep going, and move past up to up-right. You either need a 4 way, or a oscarcontrols.com restrictor plate. You can either configure the 4 way as different inputs, or wire the switches in parallel with the 8 way. The only problem there is if someone fiddles with the switch that's not in use. A quad pole double throw switch would take care of that problem.
Bob
South Carolina
Gorre
  • Last login:August 10, 2005, 07:18:15 am
  • Play it & Love it
« Reply #2 on: June 14, 2002, 12:50:11 pm »
1a.
If it is a good 4/8 way switchable you can go with one, the only problem is that for (except the ones from ultimarc/I-Pac, but I don't know how good they are)  you have to loosen four screws underneath the joystick turn the restrictor plate and fasten them again. So this remains a bit of a hassle (removing CP and screws everytime you want to switch from 8 to 4 or vice versa).
So ... for ease of use I installed 2 8-ways and 1 4-way joystick.
1b.
You don't need any reconfiguration.
You hook the 4-way stick to player 1 of the I-Pacc
You hook one 8-way to player 1 the other 8-way to player 2.
Just remember that you best don't use the 8- and 4-way joystick of player 1 together.
2.
I've used a Nvidia RIVA TNT 2 and thought it was total crap.
Now I'm using a PC - TV converter
(I'm very pleased with the result and quality)
