Author Topic: Cuphead! scratch build  (Read 46523 times)
saejansen
  • Last login:September 19, 2022, 06:25:47 am
Re: Cuphead! scratch build
« Reply #40 on: April 05, 2018, 11:44:11 am »
Did the T-molding sleeve today:
Had a little oops moment:
CPO with the T-molding applied:
« Last Edit: April 05, 2018, 11:48:10 am by saejansen »
saejansen
« Reply #41 on: April 05, 2018, 11:45:21 am »
I got this one: https://www.arcadeshop.de/Coin-Mech-Coin-Door-344x285-2-Entry_849.html
Thanks! This one is better. I think i'll go with this door.
saejansen
« Reply #42 on: April 09, 2018, 10:15:36 am »
Mounted the joysticks and Ipac today, couldn't help myself and allready applied the artwork. Came out great, especially for the price. Payed about 10 bucks a piece.
Not the prettiest mounting solution but it works:
Stressfull job:
« Last Edit: April 09, 2018, 10:17:18 am by saejansen »
saejansen
« Reply #43 on: April 09, 2018, 10:21:05 am »
Now I have to wait again for parts  :timebomb:
saejansen
« Reply #44 on: July 17, 2018, 01:34:48 pm »
Finaly had some time to work on the project again.
  • Last login:Yesterday at 02:03:18 pm
« Reply #45 on: July 17, 2018, 01:53:43 pm »
Replace the buttons with a proper coin door or go with no buttons. The way it is now looks odd.
  • Last login:February 02, 2026, 01:49:32 pm
« Reply #46 on: July 17, 2018, 02:51:40 pm »
+1.  To me a coin door is an essential part of any full-sized cabinet.  It looks as weird to me without one as it would if there was no marquee.  It's like $50 or less and takes 30 minutes to install - do it!   :cheers:
rablack97
« Reply #47 on: July 17, 2018, 04:39:57 pm »
saejansen
« Reply #48 on: September 23, 2018, 04:11:09 pm »
The project has been on pause for a while now because my girlfriend and I bought a house. Finally had (some) time to work in it again  ;D
First i wired everything up:
Gutted my old laptop:
Testing my setup, everything worked right away  :applaud:
It's starting to take its final form:
And yes I know you guys don't like the coin buttons but I currently do not have the funds to replace them with a coindoor. However in the future it will be a easy replacement.
saejansen
« Reply #49 on: September 23, 2018, 04:13:57 pm »
I would love some feedback on the power button. Anyone have an idea how i can extend this button to a arcade button?
« Reply #50 on: September 23, 2018, 04:21:11 pm »
Why did you disassemble your laptop?
saejansen
« Reply #51 on: September 23, 2018, 04:29:18 pm »
1. ---steaming pile of meadow muffin--- thermals (I'm adding a fan on the side)
2. broken screen
3. so i could extend the power button
« Reply #52 on: September 23, 2018, 04:41:00 pm »
It is probably time to get a multi meter out to see what is going where so you can solder an arcade button to that mess. Or you could just set the laptop to wake on USB. Then you could just waggle a joystick to wake it up.
JDFan
« Reply #53 on: September 23, 2018, 04:42:45 pm »
Try touching a piece of wire or similar between each pair of legs on the power button -- try each pair until you find which pair causes the laptop to start ( figure usually on those buttons 2 of the legs will be ground and 2 power so touching a wire between one of the ground and one of the power legs will usually act like pressing the button ) - Once you know which 2 places will get it to boot then attach(solder) a wire to each of those legs and wire to your momentary switch.
IE In pic attached - touch a wire between 1 and 2 and see if it boots if not try 3 and 4 - if still not try 1 and 3 etc. till it boots - ( my guess would be 1 and 2 or 3 and 4 should do it ) - Once you know that works then just solder a wire to each spot and use those for the 2 pins on your momentary button.
« Last Edit: September 23, 2018, 04:52:38 pm by JDFan »
saejansen
« Reply #54 on: September 23, 2018, 04:51:18 pm »
Thanks! Very helpfull!
saejansen
« Reply #55 on: September 23, 2018, 04:53:36 pm »
Waggle to wake sounds cool, this will be my backup plan if i can't get it working. Thanks!
JDFan
« Reply #56 on: September 23, 2018, 04:55:36 pm »
Added a pic to post above to help explain what I meant.   :cheers:
saejansen
« Reply #57 on: September 23, 2018, 04:56:23 pm »
Ian
  • Last login:September 26, 2021, 01:50:35 am
« Reply #58 on: September 23, 2018, 09:22:04 pm »
So no images of Cuphead or Mughead on the cab?
saejansen
« Reply #59 on: September 24, 2018, 02:28:09 pm »
yes, I like the devil theme better
barrymossel
  • Last login:October 29, 2021, 11:25:52 am
  • Spectrum
« Reply #60 on: September 25, 2018, 03:39:59 am »
I like this theme and build. I would have used a coin door though, or art on the front... And I don't know about the devil in the marquee...
But really a great job you are doing!
« Last Edit: October 01, 2018, 07:53:44 am by barrymossel »
yo1dog
  • Last login:November 12, 2024, 04:38:47 pm
    • MikeArcade
« Reply #61 on: September 26, 2018, 10:47:02 am »
Defiantly needs a coin door. Those fake coin door buttons just look out of place surrounded by all that empty space. Looks as if they were stuck on as an afterthought.
  • Last login:February 02, 2026, 07:47:27 pm
« Reply #62 on: September 30, 2018, 10:50:25 pm »
Is there a way to play this game without a keyboard? I'm using a PS4 controller but I'm still forced to use a keyboard to navigate menus and start levels...
saejansen
« Reply #63 on: October 01, 2018, 08:53:31 am »
Xbox one controller works fine
saejansen
« Reply #64 on: January 24, 2019, 03:09:56 pm »
Finished the project last month, here are some final pictures. I'm sorry for the image quality this room has some very poor lighting.
saejansen
« Reply #65 on: January 24, 2019, 03:15:03 pm »
Made a couple short videos of the cab in action:
Cuphead gameplay:
Street Fighter Alpha 2:
Startup sequence:
« Reply #66 on: January 24, 2019, 04:56:21 pm »
Nice job. It looks really clean.
meltman
  • Last login:April 02, 2025, 11:06:11 am
  • Brilliant!
    • forum.arcadecontrols.com/index.php/topic,158544.0.html
    • My arcade gallery
« Reply #67 on: January 25, 2019, 08:32:03 am »
Reddit gaming sure liked it :)
namonami
  • Last login:August 28, 2020, 09:40:27 am
« Reply #68 on: July 07, 2020, 10:28:13 am »
Looks great! Great job. Did you use vinyl to cover all surfaces? Or did you paint anything? Also, what size monitor is that?
  • Last login:January 29, 2026, 10:37:15 am
« Reply #69 on: July 13, 2020, 08:58:28 am »
Beautiful!  :applaud:
edekoning
« Reply #70 on: September 15, 2020, 10:33:17 am »
Wait what ... 10 bucks ... where?
Awesome looking build btw, very clean and minimal. How do you keep the control panel in place?
saejansen
« Reply #71 on: September 29, 2020, 03:03:51 pm »
Thanks! The site is called pixartprinting.nl, they are based in Italy but ship to the whole of Europe. The control panel is screwed in place from the bottom.
