Author Topic: RESOLVED: Megatouch Ion - Coin Jam Error  (Read 7744 times)
otsep
  • Last login:June 22, 2024, 10:25:51 am
  • I'm your huckleberry...
« on: March 29, 2018, 07:34:09 pm »
I have an Ion that will show a "Coin Jam" on boot every time.
I've disconnect the harness and it doesn't change the behavior. Is there anything I can do or is the only option to replace the I/O board?
« Last Edit: March 29, 2018, 09:42:05 pm by otsep »
Vids: Namco Rockin' Bowl-O-Rama
Pins: Aerosmith Pro, ST Premium Vault, Beatles Gold
Remember Wheaton's Law
mahkeymike
  • Last login:July 10, 2025, 12:42:54 pm
Re: Megatouch Ion - Coin Jam Error
« Reply #1 on: March 29, 2018, 08:45:27 pm »
Are you sure you have the right jumpers set? Disconnecting the harness wont get rid of the coin jam. You need to determine which coin mech you have and set the right jumpers.
otsep
« Reply #2 on: March 29, 2018, 09:34:16 pm »
Right now, there are no coin mechs in the unit at all. So, I'm not quite sure what to set.
otsep
« Reply #3 on: March 29, 2018, 09:41:32 pm »
Resolved
I put jumpers on JP1, JP7 & JP8 and now it is no longer complaining.
justtaint
  • Last login:September 08, 2021, 06:11:05 pm
Re: RESOLVED: Megatouch Ion - Coin Jam Error
« Reply #4 on: September 18, 2020, 06:39:19 pm »
I deleted the DBA and coin mech on a unit and rebooted into the Coin Jam error.  Putting a jumper on JP8 solved the issue thanks to your post.  There were already jumpers on JP1 and JP7.
Thank you.
