Author Topic: Original Xbox on vertical monitor  (Read 2296 times)
Gunner79
  • Last login:March 10, 2020, 10:56:29 pm
« on: March 27, 2018, 11:59:53 am »
Hello,
Wondering if anyone has had any luck running Coinops/Ninja on a vertical monitor. Any tips would be great. Thank you in advance.
  • Last login:Today at 09:07:23 pm
Re: Original Xbox on vertical monitor
« Reply #1 on: March 27, 2018, 12:29:12 pm »
CoinOps:
SETUP TATE MODE
1. Go to Option Menu
2. Select Fullscreen skin.
3. Go to Settings in Option Menu.
4. Enable ASPECT RATIO Correction.
5. Enable Advanced Setting & press Right Tigger For Visual Settings.
6. Go to Screen Mounting and select the side that you want.
7. ROTATE YOUR SCREEN & ENJOY!!!
johnnygal2
  • Last login:October 08, 2022, 03:16:04 am
« Reply #2 on: March 27, 2018, 01:40:24 pm »
There's also a CoinOps Tate build that only has the vertical games in.
Look on the CoinOps tapatalk forums.
