Author Topic: Model2emulator save hi scores  (Read 3240 times)
eldiego
  • Last login:June 07, 2024, 11:18:22 pm
  • I do my daytona twin, arcade 4 players and vpin!!!
« on: March 10, 2018, 10:33:32 am »
Hi, i can t save the hi scores when exit from m2emulator. There are any patch like mame to do this?
Nuexzz
  • Last login:October 01, 2023, 01:26:58 am
Re: Model2emulator save hi scores
« Reply #1 on: March 11, 2018, 07:24:19 pm »
here the hiscores are saved, which frontend are you using or something similar?
eldiego
« Reply #2 on: April 30, 2018, 06:58:41 pm »
Hyperspin.
Mame hi scores are saved m2emulator not save
Nuexzz
« Reply #3 on: May 04, 2018, 01:18:51 pm »
I do not use hyperspin, but the problem is that the emulator is closing badly and it will not save the last configurations, in the hyperspin forums this is your solution
you could try with ahk commands, or also with closemul
Run,% executable%% romName%,% emuPath%, Hide
Process, WaitClose,% Executable%
ExitApp
CloseProcess:
Send, {ALTDOWN} {F4} {ALTUP}
Return
eldiego
« Reply #4 on: May 04, 2018, 09:15:07 pm »
No entendi la verdad....
eldiego
« Reply #5 on: May 05, 2018, 11:27:05 am »
with that solution i don t close the emu correctly. I think the problem is m2emulator not have a keyword to close correctly the emulator. the only way that i know is kill the app and when i do this not save thye hiscores....
eldiego
« Reply #6 on: June 10, 2018, 07:03:30 pm »
Finally work. I put two buttons with joy2key "f4" and "alt" and when i press both model2emulator close correctly and save hi scores.
Thanks to all
