Author Topic: JAMMA harness - too tight?  (Read 2675 times)
jkimrey
  • Last login:February 14, 2021, 08:58:41 am
« on: February 19, 2018, 10:25:06 am »
I just recently purchased a "super" JAMMA harness from a reputable arcade supply company.
When I try to insert the game board into the JAMMA slot on the new harness, it is VERY tight and difficult to insert; so much so that I'm worried I'm going to break and/or damage the connector on the board.
I understand that there should be a tight fit, but it seems to me like it is too tight.
Has anyone experienced something like this?  Should I force the board in or is it possible this particular harness slot has an issue?
BTW - I have verified I'm inserting the board the correct (keyed) way.
TIA
« Last Edit: February 19, 2018, 10:35:15 am by jkimrey »
  • Bitches love Centipede
Re: JAMMA harness - too tight?
« Reply #1 on: February 19, 2018, 10:46:35 am »
There's your problem right there... :cheers:
%Bartop
jkimrey
« Reply #2 on: February 19, 2018, 11:09:53 am »
Perhaps :)
It was actually a harness that I have seen recommended here so I went with it...
baritonomarchetto
  • Last login:Yesterday at 02:41:34 am
« Reply #3 on: February 20, 2018, 12:52:32 am »
Have you more than one PCB at hand? Could the PCB connector be the problem?
Eventually buy a jamma harness, insert and remove it a few time and it will do the job.
jkimrey
« Reply #4 on: February 20, 2018, 03:31:44 am »
Yep - same issue/tightness with all my PCBs.  They fit fine in an older harness I have.
I'll try inserting and removing an older PCB board I have with the hope it will listen up the new harness connection...
baritonomarchetto
« Reply #5 on: February 20, 2018, 03:59:48 am »
I wrote "jamma harness" meaning "jamma fingerboard", sorry
