Author Topic: Aimtrak lightgun module xbox  (Read 4643 times)
jonny555
  • Last login:November 08, 2020, 01:04:48 pm
« on: February 10, 2018, 09:45:23 am »
Hi there
Would the aimtrak module work the original xbox with usb adapters
I currently have the aimtrak module in a ps1 gcon 45
Many thanks
« Last Edit: February 10, 2018, 11:42:25 am by jonny555 »
Titchgamer
Re: Aimtrak lightgun module xbox
« Reply #1 on: February 10, 2018, 02:15:10 pm »
To my knowledge it only supports PS & PC.
jonny555
« Reply #2 on: February 10, 2018, 06:26:05 pm »
Yeah man thanks for the reply...
I did think that it was but just wondering if there was any reason why it wouldn't being as it says it requires no drivers and just emulates a mouse
Titchgamer
« Reply #3 on: February 11, 2018, 02:36:20 am »
Give it a go, Can’t hurt ide like to see your results if it worked!
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #4 on: February 11, 2018, 07:17:43 am »
It should be detected and work as a mouse on the Xbox but not sure if any Xbox gaming applications support a mouse used as a gun.
jonny555
« Reply #5 on: February 11, 2018, 06:33:54 pm »
Comfirmed not to be working on xbox a normal mouse is in xbmc but nothing from gun
Normal mouse works in mameox operation wolf
But nothing from gun
Oh well it is old suppose
« Last Edit: February 11, 2018, 06:36:59 pm by jonny555 »
Titchgamer
« Reply #6 on: February 12, 2018, 02:36:06 am »
Thanks for trying Jonny.
Out of interest though if you are running games via a mame port is there any config options you can tweak to get it to run?
Also operation wolf was always a bit finicky to set up if I recall, maybe try something like point blank?
jonny555
« Reply #7 on: February 12, 2018, 04:16:20 pm »
I will give that a try this week
Thanks I wonder it was because I was using a hub into one port but normal mouse still worked through the hub
Titchgamer
« Reply #8 on: February 12, 2018, 04:45:08 pm »
My AT’s are plugged into a hub but that’s on a pc not a Xbox lol
