Lol, i did mean resistor
Well I forgot to mention that I did check the hot in the first place and it was good, so I did some digging through the power Supply section and found out that capacitor c-56 was bad and the ceramic resistor 103 was open. After that it fired up
Now I got a new problem, vertical collapse. I've been testing things in the vertical circuit and everything looks good, capacitors, transistors and resistors are testing good. So I'm going to replace the vertical Ic and I'll let you guys know what happens. Thanks
I checked the B+ on the big ceramic capacitor and on each pin it's giving 200 Plus on each side.
*resistor
about the only thing left is the HOT.
